Kanti
I am trying to explain Extend & Interface through anological way . Does these sound Correct !
I am trying to define the Extending and Interface definitions in an analogical way . Let me know if this will be OK ?
Extending Analogical Example
Parental Property Inheritance | The concepts of Object Oriented
| Inheritance is also the same .
Inherited Parental Property means you | It means that you have all the data variables and
had inherited every thing what your | Methods of the parent class. This enables you have
parents had without much hard work! | More lines of code with the required logic without
| much hard work.
If you are renovating your parents property | class MyPropertyClass extends ParentPropertyClass
by adding a swimming pool and car park | {
besides that house all you do is spend |//You write the body of swimming Pool;
money to build only for these two things, | //You write the body of Car Park;
so you save money by not building a house.| // You need not write about the house as you are
So if you come from aKings family you | //extending your parents house;
could inherit all your Parents,Grand Parents | }
Etc. If you destroy the property you have |
nothing and in in JAVA it is called |
Method Over-ridding. |
Even JAVA there is no limit in the number of
extensions but remember each class can extend
only one super class at a time as JAVA does not
support Multiple inheritance
INTERFACE EXAMPLE
AIRPORT CHECK-IN | CLIENT CHECK-IN.
When you want to Fly out to another | Even in OO Technique the Bean
country you can board the Aircraft | Classes are not directly Exhibited to the
only when you show your passports which | Clients but uses an Interface
has your Signature, Expiry Date etc. | which has the method structure
This means that the CLERK identifies you | i.e method signatures of the Class
through the Passport as she sees Your | with no logic or you can say
image and Signature . | Interface has the skeleton of the Class.
| The Clients talk to the bean Class
| through the interface.
| So analogically if you want to compare
| with the Airport Check-in example the
CLERK LOOKS INTO PASSPORTs TO KNOW | Clerk will be your client ,The passport which
THE PASSENGER | identifies you will be the interface as it has
| your structure i.e your PHOTO and
| Signature and you will represent
CLIENT LOOKS INTO INTERFACE TO KNOW | the bean .So without
BEAN CLASS | Passport you are not allowed to
| board the Aircraft and with out
| INTERFACE the BEAN will not do anything
| for you .
NOTE:
There will no implementation in an
INTERFACE .So INTERFACE is like having the
PHOTO of the Class.
| much hard work.
INTERFACE EXAMPLE
| for you .
NOTE:
PHOTO of the Class.
In a hospital: everybody in a long white coat and a stethoscope is taken for a doctor: INTERFACE, the patients sight.
In fact it takes many years to study and to promote to be a surgeon: EXTEND, the administration's sight.
I am a hired programmer and sit beside the customers employees.
I'm an INTERFACE (to the team) they are only intereseted in my skill.
The person right to me is a CLASS: he/she is an employee and will be promoted on success (EXTENSION).
From sheer frustration, ;JOOP!
