mcfonk
CDROM problem : drive doesn't always read CD/DVD.
I am running Windows XP on a P4 1.70Ghz, 128MB RAM system which suddenly stopped detecting my CDROM.
Since i wanted a DVD/CD-RW, i bought a Combo Drive.
Windows now detected this drive and i tried the first CD at hand.. which was read just fine.
The second disk i tried wasn't read at all. I tried restarting, changing the IDE cables, Uninstalling/Installing the secondary IDE (on which the CDROM is) but nothing worked.
Generally, (about half the times i tried), when i rebooted, the CD was detected, if i open and close the drive, then its not read anymore!
Does anyone have any ideas pls?
Thanks alot!
Mc
Thanks alot!
Mc
aslo take a look a tthe jumper setings, i have seen this problem in cable select situations and resolved it by changing drives to to master,slave.
If you have access to another computer, try and see if you still have trouble. could be a bad drive.
The cable could have gone bad. I've seen drives where the cable went bad suddenly.
The CD-ROM driver itself might have some prob. so if you have tried all the things mentioned above you might as well disconnect it and work with the combo drive.
Hope it helps
Hope it helps
could be problem with ide channel. try setting the jumper to slave and stick it on the same ide channel as hard drive.
thanks for all your help guys.. but after sometime i gave up and went out and bought another one.. which worked just fine.. it must have been some hardware conflict.
thanks again
thanks again
