jxharding
listview fill gives blank values, once column clicked and ">" is in columnheader,(descending order), only last row is filled, possible index problem
hi, i have a list view which is filled in this style:
ListView1.Items.Add(myread er("A").To String())
ListView1.Items(i).SubItem s.Add(B)
ListView1.Items(i).SubItem s.Add(MyOl eDBReader( "C").ToStr ing())
and i fill the listview via a datareader no problem
i used the following sub which i got from e-e, and it sorts a listview by column and also the first time you click on the column,
the column's name gets a ">" in front of it , the second time you click on it it gets a "<" in front of it.
now the problem i have is that once i click on a columnheader and i refill the listview, all the items in the first rows are
blank and only the last listviewitem is displayed correctly.
but if i click on it again, i can do a fill with no errors , and no blank spaces
i have tried all the columnclick subs i could find on the internet , and this one is the only one which i can actually get this far.
its as if the index is changed around.
I DO SET : LISTVIEW.SORTING = SORTORDER.NONE
, i also tried without it
this is the sub i use:
Private m_SortingColumn As ColumnHeader
' Sort using the clicked column.
Private Sub LISTVIEW1_ColumnClick(ByVa l sender As _
System.Object, ByVal e As _
System.Windows.Forms.Colum nClickEven tArgs) Handles _
ListView1.ColumnClick
' Get the new sorting column.
Dim new_sorting_column As ColumnHeader = _
ListView1.Columns(e.Column )
' Figure out the new sorting order.
Dim sort_order As System.Windows.Forms.SortO rder
If m_SortingColumn Is Nothing Then
' New column. Sort ascending.
sort_order = SortOrder.Ascending
Else
' See if this is the same column.
If new_sorting_column.Equals( m_SortingC olumn) Then
' Same column. Switch the sort order.
If m_SortingColumn.Text.Start sWith("> ") Then
sort_order = SortOrder.Descending
Else
End If
Else
End If
' Remove the old sort indicator.
m_SortingColumn.Text = _
m_SortingColumn.Text.Subst ring(2)
End If
' Display the new sort order.
m_SortingColumn = new_sorting_column
If sort_order = SortOrder.Ascending Then
m_SortingColumn.Text = "> " & m_SortingColumn.Text
Else
m_SortingColumn.Text = "< " & m_SortingColumn.Text
End If
' Create a comparer.
ListView1.ListViewItemSort er = New _
ListViewComparer(e.Column, sort_order)
' Sort.
ListView1.Sort()
End Sub
has someone had experience with this before?
im busy compiling a sample project
i've been on this for at least a good few hours!
thanks!
Else
Else
End If
Else
End If
End If
Else
End If
' Sort.
ListView1.Sort()
End Sub
thanks!
check this code
Public Class Form2
Inherits System.Windows.Forms.Form
#Region " Windows Form Designer generated code "
Public Sub New()
MyBase.New()
'This call is required by the Windows Form Designer.
InitializeComponent()
'Add any initialization after the InitializeComponent() call
End Sub
'Form overrides dispose to clean up the component list.
Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
If disposing Then
If Not (components Is Nothing) Then
components.Dispose()
End If
End If
MyBase.Dispose(disposing)
End Sub
'Required by the Windows Form Designer
Private components As System.ComponentModel.ICon tainer
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
Friend WithEvents GroupBox1 As System.Windows.Forms.Group Box
Friend WithEvents btnRefill As System.Windows.Forms.Butto n
Friend WithEvents lvwBooks As System.Windows.Forms.ListV iew
<System.Diagnostics.Debugg erStepThro ugh()> Private Sub InitializeComponent()
Me.GroupBox1 = New System.Windows.Forms.Group Box
Me.btnRefill = New System.Windows.Forms.Butto n
Me.lvwBooks = New System.Windows.Forms.ListV iew
Me.GroupBox1.SuspendLayout ()
Me.SuspendLayout()
'GroupBox1
Me.GroupBox1.Controls.Add( Me.btnRefi ll)
Me.GroupBox1.Dock = System.Windows.Forms.DockS tyle.Top
Me.GroupBox1.Location = New System.Drawing.Point(0, 0)
Me.GroupBox1.Name = "GroupBox1"
Me.GroupBox1.Size = New System.Drawing.Size(292, 100)
Me.GroupBox1.TabIndex = 0
Me.GroupBox1.TabStop = False
Me.GroupBox1.Text = "GroupBox1"
'btnRefill
Me.btnRefill.Location = New System.Drawing.Point(40, 32)
Me.btnRefill.Name = "btnRefill"
Me.btnRefill.TabIndex = 0
Me.btnRefill.Text = "Refill"
'lvwBooks
Me.lvwBooks.Dock = System.Windows.Forms.DockS tyle.Fill
Me.lvwBooks.Location = New System.Drawing.Point(0, 100)
Me.lvwBooks.Name = "lvwBooks"
Me.lvwBooks.Size = New System.Drawing.Size(292, 173)
Me.lvwBooks.TabIndex = 1
'Form2
Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13)
Me.ClientSize = New System.Drawing.Size(292, 273)
Me.Controls.Add(Me.lvwBook s)
Me.Controls.Add(Me.GroupBo x1)
Me.Name = "Form2"
Me.Text = "Form2"
Me.GroupBox1.ResumeLayout( False)
Me.ResumeLayout(False)
End Sub
#End Region
' The column currently used for sorting.
Private Sub lvwBooks_ColumnClick(ByVal sender As System.Object, ByVal e As System.Windows.Forms.Colum nClickEven tArgs) Handles lvwBooks.ColumnClick
lvwBooks.Columns(e.Column)
Else
Else
End If
Else
End If
m_SortingColumn.Text = m_SortingColumn.Text.Subst ring(2)
End If
Else
End If
lvwBooks.ListViewItemSorte r = New ListViewComparer(e.Column, sort_order)
' Sort.
lvwBooks.Sort()
End Sub
Private Sub LoadData()
lvwBooks.View = View.Details
lvwBooks.Sorting = SortOrder.None
lvwBooks.Columns.Add("Name ", 84, HorizontalAlignment.Left)
lvwBooks.Columns.Add("Site ", 84, HorizontalAlignment.Left)
lvwBooks.Columns.Add("ISBN ", 84, HorizontalAlignment.Left)
' Add data rows.
Dim i As Integer
For i = 0 To 3
lvwBooks.Items.Add("Ready- to-Run Visual Basic Algorithms" & i & "")
lvwBooks.Items(i).SubItems .Add("http://www.vb-helper.com/vba.htm" & i & "")
lvwBooks.Items(i).SubItems .Add("0-47 1-24268-3" & i & "")
Next i
' Size the columns.
'' Size the columns.
For j As Integer = 0 To lvwBooks.Columns.Count - 1
lvwBooks.Columns(j).Width = -2
Next j
End Sub
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
' Remove any existing items.
lvwBooks.Items.Clear()
LoadData()
End Sub
' Make a ListView row.
Private Sub ListViewMakeRow(ByVal lvw As ListView, ByVal item_title As String, ByVal ParamArray subitem_titles() As String)
' Make the item.
Dim new_item As ListViewItem = lvw.Items.Add(item_title)
' Make the sub-items.
For i As Integer = subitem_titles.GetLowerBou nd(0) To subitem_titles.GetUpperBou nd(0)
new_item.SubItems.Add(subi tem_titles (i))
Next i
End Sub
Private Sub Reload_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnRefill.Click
lvwBooks.Clear()
LoadData()
End Sub
End Class
Class ListViewComparer
Implements IComparer
Private m_ColumnNumber As Integer
Private m_SortOrder As SortOrder
Public Sub New(ByVal column_number As Integer, ByVal _
sort_order As SortOrder)
m_ColumnNumber = column_number
m_SortOrder = sort_order
End Sub
' Compare the items in the appropriate column
' for objects x and y.
Public Function Compare(ByVal x As Object, ByVal y As _
Object) As Integer Implements _
System.Collections.ICompar er.Compare
Dim item_x As ListViewItem = DirectCast(x, _
ListViewItem)
Dim item_y As ListViewItem = DirectCast(y, _
ListViewItem)
' Get the sub-item values.
Dim string_x As String
If item_x.SubItems.Count <= m_ColumnNumber Then
string_x = ""
Else
string_x = item_x.SubItems(m_ColumnNu mber).Text
End If
Dim string_y As String
If item_y.SubItems.Count <= m_ColumnNumber Then
string_y = ""
Else
string_y = item_y.SubItems(m_ColumnNu mber).Text
End If
' Compare them.
If m_SortOrder = SortOrder.Ascending Then
Return String.Compare(string_x, string_y)
Else
Return String.Compare(string_y, string_x)
End If
End Function
End Class
Public Class Form2
Public Sub New()
MyBase.New()
End Sub
If disposing Then
End If
End If
End Sub
Me.SuspendLayout()
'GroupBox1
'btnRefill
'lvwBooks
'Form2
Me.Name = "Form2"
Me.Text = "Form2"
End Sub
#End Region
Else
Else
End If
Else
End If
End If
Else
End If
' Sort.
lvwBooks.Sort()
End Sub
' Add data rows.
Dim i As Integer
For i = 0 To 3
Next i
' Size the columns.
Next j
End Sub
LoadData()
End Sub
' Make the item.
Next i
End Sub
lvwBooks.Clear()
LoadData()
End Sub
End Class
End Sub
ListViewItem)
ListViewItem)
string_x = ""
Else
End If
string_y = ""
Else
End If
' Compare them.
Else
End If
End Function
End Class
Instead of doing
you should do this
lvwBooks.Clear()
you should do this
lvwBooks.Clear()
sorry there is a problem with the above code
you should do both
and then
lvwBooks.Clear()
you should do both
and then
lvwBooks.Clear()
ohh no sorry problem seems to be something else
hi armoghan
i think we almost had it, but when i click on ISBN or site once
and then refill i get the same error
thanks!
thanks!
Yes the last one is working fine,
Its a work around but it is working OK with me
Have you tried the last one?
What I have done is
Before emptying the list, I have made the list in the same order as it was in the begining. So the insertion finds the same environment
What I have done is
brilliant!
this prob had me going for a good while
thank you very much!
glad i could help :)
Public Sub New()
MyBase.New()
End Sub
If disposing Then
End If
End If
End Sub
Me.SuspendLayout()
'GroupBox1
'btnRefill
'lvwBooks
'Form2
Me.Name = "Form2"
Me.Text = "Form2"
End Sub
#End Region
Else
Else
End If
Else
End If
End If
Else
End If
' Sort.
lvwBooks.Sort()
End Sub
' Add data rows.
Dim i As Integer
For i = 0 To 3
Next i
' Size the columns.
Next j
End Sub
' Make the item.
Next i
End Sub
' Add data rows.
Dim i As Integer
For i = 0 To 3
Next i
End Sub
End Class
End Sub
ListViewItem)
ListViewItem)
string_x = ""
Else
End If
string_y = ""
Else
End If
' Compare them.
Else
End If
End Function
End Class
