Need Help Converting VB Script/WMI code into VB.NET Code (Remote Process Kill)
As the subject implies, I need help converting VB Script / WMI code into VB.NET.
I need this utility to kill processes on remote machines:
Here is the current VB Script/WMI code that works:
Option Explicit
Dim objShell
Dim objNet
Dim strTitle
Dim mach
Dim Computer
Dim CompHost
Dim Process
Dim Processes
Dim StpScript
Dim StpService
Dim objWMIService
Dim colServices
Dim objService
Dim errReturnCode
Dim colProcessList
Dim objProcess
Set objShell = CreateObject("wscript.shell")
Set objNet = CreateObject("wscript.network")
mach = "test_machine_name"
Processes = Array("'radexecd'","'radsched'","'radstgms'","'radpinit'","'radskman'","'radrexxw'","'radiamsi'","'radconct'","'radpnlwr'","'nvdutils'","'wscript'")
  For Each Process In Processes
 Set objWMIService = GetObject("winmgmts:" _
    & "{impersonationLevel=impersonate}!\\" & mach & "\root\cimv2")
 Set colServices = objWMIService.ExecQuery _
    ("SELECT * FROM Win32_Service WHERE Name = "&Process&"")
  For Each objService in colServices
    errReturnCode = objService.StopService()
  Next
    Next
Now, Here is what I have in my Visual Studio VB.net form
Dim objShell
        Dim objNet
        Dim strTitle
        Dim mach
        Dim Computer
        Dim CompHost
        Dim Process
        Dim Processes As New ArrayList
        Dim StpScript
        Dim StpService
        Dim objWMIService
        Dim colServices
        Dim objService
        Dim errReturnCode
        Dim colProcessList
        Dim objProcess
        'On Error Resume Next
        mach = ComboBox2.Text
        Processes.Add("radskman")
        Processes.Add("radpinit")
        Processes.Add("radconct")
        Processes.Add("radrexxw")
        Dim strWinMgt
        Dim strQuery, strComputerName
        Dim Process_Collection
            strWinMgt = "winmgmts://" & strComputerName & ""
            strQuery = "select * from Win32_Process where Name = " & Process & ""
            Process_Collection = GetObject(strWinMgt).ExecQuery(strQuery)
            For Each objService In Process_Collection
            Next
        Next
The only real difference I am seeing here is around this line in the WMI script:
Im not sure how to set the impersonationLevel in VB.net like it should be.....
Results are if I use the .NET form, it does not stop the processes, but the VB script does.... can anyone help?
phesserAsked:
sj_hicksConnect With a Mentor Commented:
Hey phesser,
The modified code below is tested and successfully kills the process named myapp.exe.  I've only tested on current computer, but WMI shouldn't have any problems killing the processes on remote machines if you have the appropriate access.  This code requires a reference to System.Management.
        Dim strProcess As String
        Dim methodArgs() As Object = {}
        Dim strComputer As String = "."
        Dim options As New ConnectionOptions
        strProcess = "myapp.exe"
        options.Impersonation = ImpersonationLevel.Impersonate
        options.EnablePrivileges = True
        Dim ms As New ManagementScope("\\" & strComputer & "\root\CIMV2", options)
        Dim q As New SelectQuery("select * from Win32_Process where Name='" & strProcess & "'")
        Dim search As New ManagementObjectSearcher(ms, q)
        Dim wmiprocess As ManagementObject
        For Each wmiprocess In search.Get()
            wmiprocess.InvokeMethod("Terminate", methodArgs)
        Next
sj_hicksCommented:
Note that you should be using the Terminate.  The StopService method does not exist in Win32_Process.
Below is code I've use to call the WMI shutdown WMI method in VB.NET (*tested*).  This shows how one way of executing WMI methods ion VB.NET:
        ' Select all from WMI class Win32_OperatingSystem
        Dim q As New SelectQuery("SELECT * FROM Win32_OperatingSystem")
        ' methodArgs defines the options to shutdown with
        Dim methodArgs() As Object = {shutdownFlags, 0}
        ' enum each entry for Win32_OperatingSystem and call WMI Win32Shutdown method
        Dim os As ManagementObject
        For Each os In search.Get()
            os.InvokeMethod("Win32Shutdown", methodArgs)
        Next
So you'd probably need to do something like the following (*untested*) to terminate processes:
        Dim q As New SelectQuery(""select * from Win32_Process where Name=" & strProcessName)
            os.InvokeMethod("Terminate")
        Next
Hope this helps.
phesserAuthor Commented:
sj_hicks,
I tried your process and had 2 problems, here is my code snippet::
        Dim strWinMgt
            Dim q As New SelectQuery("select * from Win32_Process where Name=" & Process & "")
            Next
        Next
I had to format the line below differently:
And this line was getting an error " Overload resolution failed becase no "InvokeMethod" accepts this number of arguments"
Have any clues on how to fix it?
Raising the points, really need an answer on this one...
IMPORTANT NOTE:  These are processes that are 'spawned' from services..these are not services directly, if that makes a difference.
Also note, applications like PSKill work to kill these processes...thats what I am trying to mimic but with inherent vb.net code.
Increasing points to 350.
sj_hicks, you are the man, appreciate the help...that works quite well :)
Increasing the points to 400 for exceptional work.
