jerrycsakanyjr
Radio buttons won't work on first click to execute funtion
I have two forms in acrobat. In the first form there are 3 radio buttons that have javascript actions behind them. They do a series of actions but the first one is a  highlight funtion to bold and change the font of the texbox next to the radio button that is checked.  It works fine with the form that has 3 radio buttons, but i have another form which has only 2 radio buttons. This form doesn't bold and change the font size on the first click, you are forced to click down on it multiple times before you get the result . Where i only have to click once on the form that has the 3 radio buttons. Here is the code:
FORM 2 with 2 buttons does not work
----- start
//-----------------Do not edit the XML tags--------------------
//<Document-Level>
//<ACRO_source>highlight</ ACRO_sourc e>
//<ACRO_script>
/*********** belongs to: Document-Level:highlight ***********/
function highlight(f,selected)
// set some default style parameters
 Â
  f.richText = true; // this field does contain rich text
  f.multiline = true; // multiline
  var currentText = f.value;
  var spans = new Array();
  spans[0] = new Object();
  spans[0].text = currentText;
  if (selected)
    spans[0].fontWeight = 700;
    spans[0].textSize = 16;   Â
  else
    spans[0].fontWeight = 400;
    spans[0].textSize = 14;
 Â
  f.richValue = spans;
//</ACRO_script>
//</Document-Level>
//<Document-Level>
//<ACRO_source>highlightTe xtField(); </ACRO_sou rce>
//<ACRO_script>
/*********** belongs to: Document-Level:highlightTe xtField(); ***********/
function highlightTextField()
  // get the current setting of the radio button
  var selected = this.getField("Radio Button1").value;
  highlight(this.getField("n orecord"), selected==0);
  highlight(this.getField("r ecord"), selected==1);
//</ACRO_script>
//</Document-Level>
//<AcroForm>
//<ACRO_source>Button17:An not1:Mouse Up:Action2 </ACRO_sou rce>
//<ACRO_script>
/*********** belongs to: AcroForm:Button17:Annot1:M ouseUp:Act ion2 ***********/
var fucker = this.getField("date");
fucker.value = "";
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_source>Radio Button1:Annot1:MouseDown:A ction1</AC RO_source>
//<ACRO_script>
/*********** belongs to: AcroForm:Radio Button1:Annot1:MouseDown:A ction1 ***********/
highlightTextField();
var f1 = this.getField("controlstri ng");
var f2 = this.getField("titleno");
var f3 = this.getField("name");
var f4 = this.getField("endquote");
var f5 = this.getField("filename");
var out = this.getField("nospaces");
var out2 = this.getField("toupper");
var out3 = this.getField("noperiod");
var str = f3.value;
str = str.replace(/ /g,"");
out.value = str;
var str2= out.value;
str2 = str2.toUpperCase();
out2.value = str2;
var str3 = out2.value;
str3 = str3.replace(/[\.,-;:&]/g, "");
out3.value = str3;
f5.value = f1.value + f2.value + "PS" + out3.value + f4.value;
var created = "Document created : \n"
var date = this.getField("date");
var today= util.printd("ddd mmm dd + yyyy", new Date());
var ar = today.split(/ /);
var postfix = "";
if (ar[2] == 1 || ar[2] == 21 || ar[2] == 31)
  postfix = "st";
else if (ar[2] == 23 || ar[2] == 3)
  postfix = "rd" ;
else if (ar[2] == 2 || Â ar[2] == 22)
  postfix = "nd";
else
  postfix = "th";
today = ar[0] + "Â " + ar[1] + "Â " + ar[2] + postfix;
var year= util.printd("yyyy", new Date());
date.value = created + today + "Â " + year;
date.fillColor= color.white;
date.textColor = color.black;
var titlenum = this.getField("titleno");
var id = this.getField("id");
id.value = titlenum.value + "-" + Math.round(Math.random() * 99999)
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_source>Radio Button1:Annot2:MouseUp:Act ion1</ACRO _source>
//<ACRO_script>
/*********** belongs to: AcroForm:Radio Button1:Annot2:MouseUp:Act ion1 ***********/
var str = f3.value;
out.value = str;
out2.value = str2;
out3.value = str3;
var postfix = "";
  postfix = "st";
  postfix = "rd" ;
  postfix = "nd";
else
  postfix = "th";
//</ACRO_script>
//</AcroForm>
--end
FORM 2 with 2 buttons (not working)
---start
//<Document-Level>
//<ACRO_script>
function highlight(f, selected)
 Â
  if (selected)
  else
 Â
//</ACRO_script>
//</Document-Level>
//<Document-Level>
//<ACRO_script>
  highlight(this.getField("n ocase"), selected==0);
  highlight(this.getField("c ase"), selected==1);
  highlight(this.getField("s ocial"), selected==2);
//</ACRO_script>
//</Document-Level>
//<AcroForm>
//<ACRO_source>Radio Button1:Annot1:MouseUp:Act ion1</ACRO _source>
//<ACRO_script>
/*********** belongs to: AcroForm:Radio Button1:Annot1:MouseUp:Act ion1 ***********/
var str = f3.value;
out.value = str;
out2.value = str2;
str3 = str3.replace(/[\.',;:&-]/g , "");
out3.value = str3;
f5.value = f1.value + f2.value + "BK" + out3.value + f4.value;
var postfix = "";
  postfix = "st";
  postfix = "rd" ;
  postfix = "nd";
else
  postfix = "th";
var pp = this.getPrintParams();
pp.interactive = pp.constants.interactionLe vel.automa tic;
pp.printerName = "up-middle";
this.print(pp);
var pp2 = this.getPrintParams();
pp2.interactive = pp.constants.interactionLe vel.automa tic;
pp2.printerName = "Bankruptcy and Patriot";
this.print(pp2);
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_script>
var str = f3.value;
out.value = str;
out2.value = str2;
out3.value = str3;
var postfix = "";
  postfix = "st";
  postfix = "rd" ;
  postfix = "nd";
else
  postfix = "th";
pp2.interactive = pp2.constants.interactionL evel.autom atic;
pp2.printerName = "up-middle"
this.print(pp2);
pp.printerName = "Bankruptcy and Patriot"
this.print(pp);
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_source>Radio Button1:Annot3:MouseUp:Act ion1</ACRO _source>
//<ACRO_script>
/*********** belongs to: AcroForm:Radio Button1:Annot3:MouseUp:Act ion1 ***********/
var str = f3.value;
out.value = str;
out2.value = str2;
out3.value = str3;
var postfix = "";
  postfix = "st";
  postfix = "rd" ;
  postfix = "nd";
else
  postfix = "th";
this.print(pp);
this.print(pp2);
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_source>county:Keys troke</ACR O_source>
//<ACRO_script>
/*********** belongs to: AcroForm:county:Keystroke ***********/
/* This version updates a secondary combobox based on the entry selected by
** the user dynamically. The keystroke event should be processed until the
** value is about to be committed (as indicated by event.willCommit). */
if (!event.willCommit) {
   var f = this.getField("district");
   f.clearItems();
   Â
   /* In a keystroke event, event.change contains the non-export value of
   ** the item selected by the user. */
   switch (event.change) {
     case "Suffolk":
        f.setItems(["Eastern"]);
        break;
        case "Nassau":
     break;
     case "Kings":
     break;
     case "Queens":
     break;
     case "Richmond":
     break;
     case "Broome":
        f.setItems(["Northern"]);
     break;
     case "Cayuga":
     break;
     case "Albany":
     break;
     case "Bronx":
        f.setItems(["Southern"]);
     break;
     case "Allegheny":
        f.setItems(["Western"]);
     break;
        case "Chenango":
     break;
        case "Clinton":
     break;
        case "Columbia":
        break;
        case "Cortland":
        break;
        case "Delaware":
        break;
        case "Essex":
        break;
        case "Franklin":
        break;
        case "Fulton":
        break;
        case "Greene":
        break;
        case "Hamilton":
        break;
        case "Herkimer":
        break;
        case "Jefferson":
        break;
        case "Lewis":
        break;
        case "Madison":
        break;
        case "Montgomery":
        break;
        case "Oneida":
        break;
        case "Onondaga":
        break;
        case "Oswego":
        break;
        case "Otsego":
        break;
        case "Rensselaer":
        break;
        case "Saint Lawrence":
        break;
        case "Saratoga":
        break;
        case "Schoharie":
        break;
        case "Schenctedy":
        break;
        case "Tioga":
        break;
        case "Tompkins":
        break;
        case "Ulster":
        break;
        case "Warren":
        break;
        case "Washington":
        break;
        case "Dutchess":
     break;
        case "New York":
     break;
        case "Orange":
     break;
        case "Putnam":
     break;
        case "Rockland":
     break;
        case "Sullivan":
     break;
        case "Westchester":
     break;
        case "Waters":
     break;
        case "Cattaraugus":
     break;
        case "Chautauqua":
     break;
        case "Chemug":
     break;
        case "Erie":
     break;
        case "Genesee":
       break;
        case "Livingston":
     break;
        case "Monroe":
     break;
        case "Niagara":
     break;
        case "Ontario":
     break;
        case "Orleans":
     break;
        case "Schuyler":
     break;
        case "Seneca":
     break;
        case "Steuben":
     break;
        case "Wayne":
     break;        Â
        case "Wyoming":
     break;
        case "Yates":
     break;
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_source>reset:Annot 1:MouseUp: Action1</A CRO_source >
//<ACRO_script>
/*********** belongs to: AcroForm:reset:Annot1:Mous eUp:Action 1 ***********/
var clr = this.getField("date");
clr.value = "";
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_source>search:Keys troke</ACR O_source>
//<ACRO_script>
/*********** belongs to: AcroForm:search:Keystroke ***********/
   var f = this.getField("county");
    var g = this.getField("district");
  Â
     case "Suffolk":
        f.setItems(["Suffolk"]);
            g.setItems(["Eastern"]);
     break;
        case "Nassau":
            f.setItems(["Nassau"]);
        break;
        case "Kings":
            f.setItems(["Kings"]);
        break;
        case "Queens":
            f.setItems(["Queens"]);
        break;
        case "Richmond":
            f.setItems(["Richmond"]);
        break;
        case "Broome":
            f.setItems(["Broome"]);
            g.setItems(["Northern"]);
        break;
        case "Cayuga":
            f.setItems(["Cayuga"]);
        break;
        case "Albany":
            f.setItems(["Albany"]);
        break;
        case "Bronx":
            f.setItems(["Bronx"]);
            g.setItems(["Southern"]);
        break;
        case "Yates":
            f.setItems(["Yates"]);
            g.setItems(["Western"]);
        break;
        case "Allegheny":
            f.setItems(["Allegheny"]);
        break;
        case "Chenango":
            f.setItems(["Chenango"]);
        break;
        case "Clinton":
            f.setItems(["Clinton"]);
        break;
        case "Columbia":
            f.setItems(["Columbia"]);
        break;
        case "Cortland":
            f.setItems(["Cortland"]);
        break;
        case "Delaware":
            f.setItems(["Delaware"]);
        break;
        case "Essex":
            f.setItems(["Essex"]);
        break;
        case "Franklin":
            f.setItems(["Franklin"]);
        break;
        case "Fulton":
            f.setItems(["Fulton"]);
        break;
        case "Greene":
            f.setItems(["Greene"]);
        break;
        case "Hamilton":
            f.setItems(["Hamilton"]);
        break;
        case "Herkimer":
            f.setItems(["Herkimer"]);
        break;
        case "Jefferson":
            f.setItems(["Jefferson"]);
        break;
        case "Lewis":
            f.setItems(["Lewis"]);
        break;
        case "Madison":
            f.setItems(["Madison"]);
        break;
        case "Montgomery":
            f.setItems(["Montgomery"]) ;
        break;
        case "Oneida":
            f.setItems(["Oneida"]);
        break;
        case "Onondaga":
            f.setItems(["Onondaga"]);
        break;
        case "Oswego":
            f.setItems(["Oswego"]);
        break;
        case "Otsego":
            f.setItems(["Otsego"]);
        break;
        case "Rensselaer":
            f.setItems(["Rensselaer"]) ;
        break;
            f.setItems(["Saint Lawrence"]);
        break;
        case "Saratoga":
            f.setItems(["Saratoga"]);
        break;
        case "Schoharie":
            f.setItems(["Schoharie"]);
        break;
        case "Schenctedy":
            f.setItems(["Schenctedy"]) ;
        break;
        case "Tioga":
            f.setItems(["Tioga"]);
        break;
        case "Tompkins":
            f.setItems(["Tompkins"]);
        break;
        case "Ulster":
            f.setItems(["Ulster"]);
        break;
        case "Warren":
            f.setItems(["Warren"]);
        break;
        case "Washington":
            f.setItems(["Washington"]) ;
        break;
        case "Dutchess":
            f.setItems(["Dutchess"]);
        break;
        case "New York":
            f.setItems(["New York"]);
        break;
        case "Orange":
            f.setItems(["Orange"]);
        break;
        case "Putnam":
            f.setItems(["Putnam"]);
        break;
        case "Rockland":
            f.setItems(["Rockland"]);
        break;
        case "Sullivan":
            f.setItems(["Sullivan"]);
        break;
        case "Westchester":
            f.setItems(["Westchester"] );
        break;
        case "Waters":
            f.setItems(["Waters"]);
        break;
        case "Cattaraugus":
            f.setItems(["Cattaraugus"] );
        break;
        case "Chautauqua":
            f.setItems(["Chautauqua"]) ;
        break;
        case "Chemung":
            f.setItems(["Chemung"]);
        break;
        case "Erie":
            f.setItems(["Erie"]);
        break;
        case "Genesee":
            f.setItems(["Genesee"]);
        break;
        case "Livingston":
            f.setItems(["Livingston"]) ;
        break;
        case "Monroe":
            f.setItems(["Monroe"]);
        break;
        case "Niagara":
            f.setItems(["Niagara"]);
        break;
        case "Ontario":
            f.setItems(["Ontario"]);
        break;
        case "Orleans":
            f.setItems(["Orleans"]);
        break;
        case "Schuyler":
            f.setItems(["Schuyler"]);
        break;
        case "Seneca":
            f.setItems(["Seneca"]);
        break;
        case "Steuben":
            f.setItems(["Steuben"]);
        break;
        case "Wayne":
            f.setItems(["Wayne"]);
        break;
        case "Wyoming":
            f.setItems(["Wyoming"]);
        break;
//</ACRO_script>
//</AcroForm>
---end
----- start
//<Document-Level>
//<ACRO_script>
 Â
  if (selected)
  else
 Â
//</ACRO_script>
//</Document-Level>
//<Document-Level>
//<ACRO_script>
//</ACRO_script>
//</Document-Level>
//<AcroForm>
//<ACRO_script>
fucker.value = "";
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_script>
var str = f3.value;
out.value = str;
out2.value = str2;
out3.value = str3;
var postfix = "";
  postfix = "st";
  postfix = "rd" ;
  postfix = "nd";
else
  postfix = "th";
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_script>
var str = f3.value;
out.value = str;
out2.value = str2;
out3.value = str3;
var postfix = "";
  postfix = "st";
  postfix = "rd" ;
  postfix = "nd";
else
  postfix = "th";
//</ACRO_script>
//</AcroForm>
--end
---start
//<Document-Level>
//<ACRO_script>
 Â
  if (selected)
  else
 Â
//</ACRO_script>
//</Document-Level>
//<Document-Level>
//<ACRO_script>
//</ACRO_script>
//</Document-Level>
//<AcroForm>
//<ACRO_script>
var str = f3.value;
out.value = str;
out2.value = str2;
out3.value = str3;
var postfix = "";
  postfix = "st";
  postfix = "rd" ;
  postfix = "nd";
else
  postfix = "th";
this.print(pp);
this.print(pp2);
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_script>
var str = f3.value;
out.value = str;
out2.value = str2;
out3.value = str3;
var postfix = "";
  postfix = "st";
  postfix = "rd" ;
  postfix = "nd";
else
  postfix = "th";
this.print(pp2);
this.print(pp);
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_script>
var str = f3.value;
out.value = str;
out2.value = str2;
out3.value = str3;
var postfix = "";
  postfix = "st";
  postfix = "rd" ;
  postfix = "nd";
else
  postfix = "th";
this.print(pp);
this.print(pp2);
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_script>
   f.clearItems();
   Â
     case "Suffolk":
        break;
        case "Nassau":
     break;
     case "Kings":
     break;
     case "Queens":
     break;
     case "Richmond":
     break;
     case "Broome":
     break;
     case "Cayuga":
     break;
     case "Albany":
     break;
     case "Bronx":
     break;
     case "Allegheny":
     break;
        case "Chenango":
     break;
        case "Clinton":
     break;
        case "Columbia":
        break;
        case "Cortland":
        break;
        case "Delaware":
        break;
        case "Essex":
        break;
        case "Franklin":
        break;
        case "Fulton":
        break;
        case "Greene":
        break;
        case "Hamilton":
        break;
        case "Herkimer":
        break;
        case "Jefferson":
        break;
        case "Lewis":
        break;
        case "Madison":
        break;
        case "Montgomery":
        break;
        case "Oneida":
        break;
        case "Onondaga":
        break;
        case "Oswego":
        break;
        case "Otsego":
        break;
        case "Rensselaer":
        break;
        break;
        case "Saratoga":
        break;
        case "Schoharie":
        break;
        case "Schenctedy":
        break;
        case "Tioga":
        break;
        case "Tompkins":
        break;
        case "Ulster":
        break;
        case "Warren":
        break;
        case "Washington":
        break;
        case "Dutchess":
     break;
        case "New York":
     break;
        case "Orange":
     break;
        case "Putnam":
     break;
        case "Rockland":
     break;
        case "Sullivan":
     break;
        case "Westchester":
     break;
        case "Waters":
     break;
        case "Cattaraugus":
     break;
        case "Chautauqua":
     break;
        case "Chemug":
     break;
        case "Erie":
     break;
        case "Genesee":
       break;
        case "Livingston":
     break;
        case "Monroe":
     break;
        case "Niagara":
     break;
        case "Ontario":
     break;
        case "Orleans":
     break;
        case "Schuyler":
     break;
        case "Seneca":
     break;
        case "Steuben":
     break;
        case "Wayne":
     break;        Â
        case "Wyoming":
     break;
        case "Yates":
     break;
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_script>
clr.value = "";
//</ACRO_script>
//</AcroForm>
//<AcroForm>
//<ACRO_script>
  Â
     case "Suffolk":
     break;
        case "Nassau":
        break;
        case "Kings":
        break;
        case "Queens":
        break;
        case "Richmond":
        break;
        case "Broome":
        break;
        case "Cayuga":
        break;
        case "Albany":
        break;
        case "Bronx":
        break;
        case "Yates":
        break;
        case "Allegheny":
        break;
        case "Chenango":
        break;
        case "Clinton":
        break;
        case "Columbia":
        break;
        case "Cortland":
        break;
        case "Delaware":
        break;
        case "Essex":
        break;
        case "Franklin":
        break;
        case "Fulton":
        break;
        case "Greene":
        break;
        case "Hamilton":
        break;
        case "Herkimer":
        break;
        case "Jefferson":
        break;
        case "Lewis":
        break;
        case "Madison":
        break;
        case "Montgomery":
        break;
        case "Oneida":
        break;
        case "Onondaga":
        break;
        case "Oswego":
        break;
        case "Otsego":
        break;
        case "Rensselaer":
        break;
        break;
        case "Saratoga":
        break;
        case "Schoharie":
        break;
        case "Schenctedy":
        break;
        case "Tioga":
        break;
        case "Tompkins":
        break;
        case "Ulster":
        break;
        case "Warren":
        break;
        case "Washington":
        break;
        case "Dutchess":
        break;
        case "New York":
        break;
        case "Orange":
        break;
        case "Putnam":
        break;
        case "Rockland":
        break;
        case "Sullivan":
        break;
        case "Westchester":
        break;
        case "Waters":
        break;
        case "Cattaraugus":
        break;
        case "Chautauqua":
        break;
        case "Chemung":
        break;
        case "Erie":
        break;
        case "Genesee":
        break;
        case "Livingston":
        break;
        case "Monroe":
        break;
        case "Niagara":
        break;
        case "Ontario":
        break;
        case "Orleans":
        break;
        case "Schuyler":
        break;
        case "Seneca":
        break;
        case "Steuben":
        break;
        case "Wayne":
        break;
        case "Wyoming":
        break;
//</ACRO_script>
//</AcroForm>
---end
I found your question, but it will take a while to walk through the code. I'll be back ...
Would help if i just emailed you the forms ?
EE prefers that you make it available on the web (so that other experts also have access to it).
If this is not possible, you can find my email address in my profile.
Did you send the files?
There is a lot of duplicate code in the button handlers. You should factor this out into a document level function (the same way you are doing this for the highlight() function).
I looked at the code, but without the actual form, it's pretty complicated (almost impossible) to find out what's wrong. I started to recreate your forms, but had to stop because I have no idea if my interpretation of your code is correct. So, if you can make the actual files available, it would be much easier.
Thank you!!
