Problems converting method from 16bit to 32bit... please help!
I think i managed to convert some 16bit method to its 32bit equivalent, but when i attempt to execute it on the legacy platform, it behaves differently compared to the original method. Please could someone check if i have converted the code correctly, as im not sure what could be wrong. Thanks.
Original 16bit method
int ReceiveData(void)
      COMSTAT         CommsState;
      int                     iError;
      int             Length;
      int                     ByteCount;
      if (bCommsOK)
            iError = GetCommError(iCommsID, &CommsState);
            if (iError == 0)
                  Length = CommsState.cbInQue;
          /*Check if there is any data buffered by Windows to be read */
                  if (Length > 0)
            /*Make sure the buffer is big enough to recieve the     */
                        /*buffered data        */
                        if ((BUFSIZE - RxBuf.Count) < Length)
                              /*buffer does not have enough room to receive all       */
                              /*the buffered data.  So throw away data untill     */
                              /*it will fit.        */
                              while ((Length > 0) && (iError >= 0))
                                    if (Length > BUFSIZE)
                                          ByteCount = BUFSIZE;
                                    else
                                          ByteCount = Length;
                                    Length -= ByteCount;
                                    iError = ReadComm(iCommsID,&RxBuf.Buf[0],ByteCount);
                              Length = ByteCount;
                              RxBuf.Count = ByteCount;
                              RxBuf.op = 0;
                              RxBuf.ip = ByteCount;
            else
                              /*Receive the data        */
                              /* If necessary, receive the data in two passes,                */
                              /* wrapping around the buffer.                                                  */
                              if ((BUFSIZE - RxBuf.ip) < Length)
                                    /* Fill to end of buffer.                                                       */
                                    iError = ReadComm(iCommsID, &RxBuf.Buf[RxBuf.ip],
                                                             BUFSIZE - RxBuf.ip);
                                    if (iError > 0)
                                          /* Now put the rest in the start of the buffer. */
                                          iError = ReadComm(iCommsID, &RxBuf.Buf[0],
        Length - BUFSIZE - RxBuf.ip);
                                          /* Wrap the input pointer.                                              */
                                          RxBuf.ip = ((RxBuf.ip + Length) %BUFSIZE);
                                          /* Update the number of chars in the buffer     */
                                          RxBuf.Count += Length;
                              /* otherwise just receive it in 1 go.                                   */
                              else
                                    iError = ReadComm(iCommsID, &RxBuf.Buf[RxBuf.ip],Length);
                                    /* Update input posn and number of chars in buffer      */
                                    RxBuf.ip += Length;
                        if (iError < 0)
                              return -4200 - iError;
                              /* Comms Read Error     */
                        else
                              if      (iError == 0)
                                    if (iError != 0)
                                          return -4400 - iError;
                                    else
                                          return Length; /*Number of bytes transferred*/
                  else
                        return 0;       /* No data to be transferred                            */
            else
                  return -4600 - iError;
                  /*Comms Read channel Fault */
      else
            return -4800;
Converted 32bit method
      COMSTAT CommsState;
      int iError;
      int Length;
      int ByteCount;
      int nBytesRead;
      int dwErrors;
      char buffer[255];
      if (bCommsOK)
            log_(LOG_LEVEL_INFO,INF_RECEIVE_DATA,"","");
            iError = GetCommState(hComm, &dcb);
            if (iError == 0)
                  ClearCommError(hComm, &dwErrors, &CommsState); // Get ComState
                  // Check if there is any data buffered by Windows to be read
                  if (Length > 0)
                        // Make sure the buffer is big enough to recieve the buffered data        */
                              // buffer does not have enough room to receive all the
                              // buffered data.  So throw away data untill it will fit.        */
                                    else
                                          ByteCount = Length;
                                    // Attempt a synchronous read operation.
                                    iError = ReadFile(hComm, &RxBuf.Buf[0], ByteCount,
                                          &nBytesRead, NULL) ;
                              Length = ByteCount;
                              RxBuf.op = 0;
            else
                              // Receive the data If necessary, receive the data in two
                              // passes, wrapping around the buffer.
                                    // Fill to end of buffer.
                                    iError = ReadFile(hComm, &RxBuf.Buf[RxBuf.ip], BUFSIZE
                                          - RxBuf.ip, &nBytesRead, NULL);
                                    if (iError > 0)
                                          // Now put the rest in the start of the buffer.
                                          iError = ReadFile(hComm, &RxBuf.Buf[0], Length -
                                                BUFSIZE - RxBuf.ip, &nBytesRead, NULL);
                                          // Wrap the input pointer.
                                          // Update the number of chars in the buffer
                              // otherwise just receive it in 1 go.
                              else
                                    iError = ReadFile(hComm, &RxBuf.Buf[RxBuf.ip], Length,
                                          &nBytesRead, NULL);
                                    // Update input posn and number of chars in buffer
                                    RxBuf.ip += Length;
                        if (iError < 0)
                              itoa(iError,buffer,2);
                              log_(LOG_LEVEL_ERROR,ERR_RECEIVE_DATA, buffer, "");
                              // Comms Read Error
                        else
                              if      (iError == 0)
                                    if (iError != 0)
                                          // Comms Read Error
                                    else
                                          return Length; // Number of bytes transferred
                  else
                        return 0; // No data to be transferred
            else
                  // Comms Read channel Fault
      else
            return -4800;
      return 0;
Actia
Actia
grg99Commented:
The problem is likely to be in the lengths of "int".
first look in whatever header file defines the ReadFile() API's, you should see something like "INT16 * ReadLen" for the 4th parameter to ReadFile.
Try using the ORIGINAL 16-bit code, but change all the "int" vars to INT16 or whatever type the header file says.
Then change any other int's to that type if they are used in math with that INT16 variable.
Also compile it with all warnings turned on, it should warn about int length incompatibilities a lot better with warnings turned on.
PaulCaswellCommented:
Whats the difference? What goes wrong?
Paul
ActiaAuthor Commented:
It does not receive response from the rig, so therefore something can't be right, but all i have done is convert api from 16bit to 32bit equivallents
KuppingerCole Reviews AlgoSec in Executive Report
Leading analyst firm, KuppingerCole reviews AlgoSec's Security Policy Management Solution, and the security challenges faced by companies today in their Executive View report.
Does the actual conversion itself seem correct? The trouble is i am unable to debug the code, and the only testing I can do is offsite
Heh problem was solved, the issue was due to
          if (iError == 0)
16bit GetCommError returns 0 if successfull and a non zero value if an error occurs.
32bit GetCommState returns 1 if successfull and a minus value if an error occurs!
The actual methods were never executed and would always return an Error, cos to be successfull it was expecting a value of 1.
Doh! Problem solved! :)
GhostModCommented:
PAQd, 250 points refunded.
GhostMod
Community Support Moderator
Free Tool: IP Lookup
