Help with PL/SQL to T-SQL conversion.
Hi Guys, I need some in SQL conversion from Oracle to SQL Server...Here is the procedure in T-SQL..When I run the below SQL in SQL Server, it is going in infinite loop. When I click stop, I am getting the error .......
"Invalid length parameter passed to the substring function."
at the following line
SELECT @RoleID_in = CONVERT(NUMERIC(8, 2), SUBSTRING(@UserRoles_in, 1, CHARINDEX(',', @UserRoles_in) - 1))
DECLARE @objid_in INT
DECLARE @objclass_in INT
DECLARE @userid_in INT
DECLARE @userRoles_in VARCHAR(3000)
DECLARE @RoleID_in INT
DECLARE @cnt INT
DECLARE csr CURSOR FOR
SELECT * FROM objectACL
OPEN csr
WHILE (0 = 0)
BEGIN --(
fetch NEXT FROM csr INTO @objid_in, @objclass_in, @userid_in, @userRoles_in
IF (@@FETCH_STATUS = -1)
BREAK
SELECT @UserRoles_in = SUBSTRING(@UserRoles_in, 2, LEN(@UserRoles_in))
WHILE (0 = 0)
BEGIN --(
SELECT @cnt = COUNT(*) FROM nodetable WHERE objtype = 21 AND id = @RoleId_in
IF ( @cnt = 0 )
BEGIN
INSERT INTO error_report VALUES( 'ObjectACL' , '0' , 'UserRoles refering to Non-existing Role : ' + CAST(@RoleID_in AS VARCHAR) )
END
SELECT @UserRoles_in = SUBSTRING(@UserRoles_in, LEN(@RoleID_in) + 2, LEN(@UserRoles_in))
IF ( @UserRoles_in is null )
BEGIN
BREAK
END
END --)
END --)
close csr
DEALLOCATE csr
GO
Corresponding procedure in Oracle
declare
cursor csr is select * from objectACL;
objid_in number;
objclass_in number;
userid_in number;
userRoles_in varchar2(3000);
RoleID_in number;
cnt number;
begin
open csr;
loop
fetch csr into objid_in, objclass_in, userid_in, userRoles_in;
exit when csr%notfound;
UserRoles_in := substr(UserRoles_in, 2);
loop
RoleID_in := to_number(substr(UserRoles_in, 1, instr(UserRoles_in, ',')-1));
select count(1) into cnt from nodetable where objtype=21 and id=RoleId_in;
if (cnt =0) then
insert into error_report values ('ObjectACL', '0', 'UserRoles refering to Non-existing Role : '||RoleId_in);
end if;
UserRoles_in := substr(userRoles_in, length(RoleId_in)+2);
if (userRoles_in is null) then
exit;
end if;
end loop;
end loop;
close csr;
end;
kingno1Asked:
ChrisFretwellConnect With a Mentor Commented:
cant really see the null being a problem, but just in case.....let me think.....
SELECT @RoleID_in = case when @userroles_in is null then 0 else CONVERT(NUMERIC(8, 2), SUBSTRING(@UserRoles_in, 1, case when (CHARINDEX(',', @UserRoles_in) - 1)>0 then  (CHARINDEX(',', @UserRoles_in) - 1) else len(@userRoles_in) end)) end
ChrisFretwellCommented:
If there is no match returned from the charindex, then your length would be 0-1 or -1, which is an invalid length. Thats my guess.
If it is, you can fix it easily with the abs function
SELECT @RoleID_in = CONVERT(NUMERIC(8, 2), SUBSTRING(@UserRoles_in, 1, abs(CHARINDEX(',', @UserRoles_in)) - 1))
If that doesnt fix it, I'd need to really see the data to know why its failing.
Wait, ignore that solution, since it wouldnt return waht you want. Try
SELECT @RoleID_in = CONVERT(NUMERIC(8, 2), SUBSTRING(@UserRoles_in, 1, case when (CHARINDEX(',', @UserRoles_in)> 1 - 1)>0 then  CHARINDEX(',', @UserRoles_in)> 1 - 1) else len(@userRoles_in) end)
What Kind of Coding Program is Right for You?
There are many ways to learn to code these days. From coding bootcamps like Flatiron School to online courses to totally free beginner resources. The best way to learn to code depends on many factors, but the most important one is you. See what course is best for you.
kingno1Author Commented:
Hi, Thanks..
I get the error...
Server: Msg 170, Level 15, State 1, Line 22
Line 22: Incorrect syntax near '>'.
Server: Msg 156, Level 15, State 1, Line 36
Incorrect syntax near the keyword 'END'.
Partha MandayamTechnical DirectorCommented:
SELECT @RoleID_in = CONVERT(NUMERIC(8, 2), SUBSTRING(@UserRoles_in, 1, case when (CHARINDEX(',', @UserRoles_in - 1)>0 then  CHARINDEX(',', @UserRoles_in - 1) else len(@userRoles_in) end)
sorry, typo when I was cutting and pasting. hopefuly the other one works.
I dont know pl/sql to now if it uses cases, but if not and you want a quick explanation, let me know.
Hi, I used the above syntax and got the error after I remove end at the end
Server: Msg 156, Level 15, State 1, Line 22
Incorrect syntax near the keyword 'then'.
Let me check the brackets out.....okay, this should work
SELECT @RoleID_in = CONVERT(NUMERIC(8, 2), SUBSTRING(@UserRoles_in, 1, case when CHARINDEX(',', @UserRoles_in - 1)>0 then  CHARINDEX(',', @UserRoles_in - 1) else len(@userRoles_in) end)
There was one extra bracket at the beginning.
Case statements are a bit like if then else for inline use. The format is
CASE
WHEN condition THEN value
ELSE value
END
You dont need an else, but you do need the end. The problem in teh statemetn above wasnt with the end, it was the bracket before charindex that wasnt ended before the > symbol it didnt know what to do with the end or the then or anything else.
Hmm, Looks like the stament is correct but, there is some syntax error..
CHRIS, can you please remove that extra bracket and post the statement if you dont mind..
Thanks a lot again.
SELECT @RoleID_in = CONVERT(NUMERIC(8, 2), SUBSTRING(@UserRoles_in, 1, case when (CHARINDEX(',', @UserRoles_in) - 1)>0 then  (CHARINDEX(',', @UserRoles_in) - 1) else len(@userRoles_in) end))
Tested in sql, all syntax errors are gone
Awesome, the error is gone..After executing my SQL, it returned the error..
Server: Msg 8114, Level 16, State 5, Line 20
Error converting data type varchar to numeric.
Here is my DDL..Any pointers please?
CREATE TABLE [dbo].[OBJECTACL] (
      [OBJID] [numeric](28, 0) NOT NULL ,
      [OBJCLASS] [numeric](28, 0) NOT NULL ,
      [USERID] [numeric](28, 0) NOT NULL ,
      [USERROLES] [varchar] (2000)  NULL
) ON [PRIMARY]
GO
The problem is because of data in our userroles field.
You're convert with the new case statement says to (in english)
take all characters up to the first comma (all characters if there is no comma) and convert them to a numeric value
This will work if your data supports it, for example the following values in userroles would work
1234,asefjs
1234556
1234,4565l
123.4,sedfwet
however these values would give you the error
123f,5
1234t
abvcd
Are there any rules for the format of the user roles column?
Will there always be a comma (we know there isnt or you wouldnt have had your first error)
Will the substring always return a numeric only string? Nope again.
If you need to, I can give you code to check to see if the value returned from the substring is numeric before you run the convert. What you need to do is specify what value you want returned if the substring isnt an acceptible value.
All the values are
,9010,
,9010,9011,
However I see some NULL values too. There are no alphabets though.
Hmm, Same error..
I dont see any other data except that.
Its data. its the only ting it can be. oh, if any of your numbers are more than can fit into numeric(8,2)?
Can I send you my OBJECTACL and NODETABLE that were involved in this procedure?
If I can, what will be the email address.
Thanks a lot again.
why don't you just do a convert to int instead of numeric(8,2)
I looked at your entire code again.
You can just declare @role_id_in as varchar(20) instead of int.
Then you don't need the convert(numeric(8,2))
Hi, I tried withconvert to  INT as CHRIS suggested and VARCHAR(20) as mcp111 suggested
Both are running but for a long time, after 7 minutes of run, I stopped the execution and it showed a lot of rows affected in the log.
Looks like it is going in a loop...
MCP, as you suggested, can you convert that that select statement without CONVERT if I declare roleid_in as varchar(20).
Yes, it would just be
SELECT @RoleID_in = SUBSTRING(@UserRoles_in, 1, case when (CHARINDEX(',', @UserRoles_in) - 1)>0 then  (CHARINDEX(',', @UserRoles_in) - 1) else len(@userRoles_in) end)
Got the same error, converting data type to numeric at the very next statement..
That means you have some non-numeric data
try this
if isnumeric( @RoleId_in)
Server: Msg 156, Level 15, State 1, Line 25
Incorrect syntax near the keyword 'SELECT'.
WHILE (0 = 0)
            BEGIN --(
                  --SELECT @RoleID_in  = CONVERT(NUMERIC(8, 2), SUBSTRING(@UserRoles_in, 1, CHARINDEX(',', @UserRoles_in) - 1))
mironCommented:
-- replace
if (userRoles_in is null) then exit
-- with
if ( @UserRoles_in IS NULL OR rtrim(ltrim(@UserRoles_in)) = '' ) break
-- cheers
Hi, Here is my whole procedure as of now..Can you please tell me where to replace?
DECLARE @RoleID_in                                varchar(20)
DECLARE @cnt                                      INT
      OPEN csr
      WHILE (0 = 0)
      BEGIN --(
            BREAK
            WHILE (0 = 0)
            BEGIN --(
                  IF ( @cnt = 0 )
                  BEGIN
                  END
                  BEGIN
                        BREAK
                  END
               END --)
      END --)
      close csr
DEALLOCATE csr
GO
mironCommented:
DECLARE @cnt                                      INT
     OPEN csr
     WHILE (0 = 0)
     BEGIN --(
          BREAK
          WHILE (0 = 0)
          BEGIN --(
               IF ( @cnt = 0 )
               BEGIN
               END
--- replace here ==============>>>>>               IF ( @UserRoles_in is null )  <<<<<< ============== replace here
--==============>>>>>                 BEGIN
--==============>>>>>                      BREAK
--==============>>>>>                 END
             END --)
     END --)
     close csr
DEALLOCATE csr
GO
Didnt help me
mironCommented:
-- check if this still produces  error
DECLARE @cnt                                      INT
     OPEN csr
     WHILE (0 = 0)
     BEGIN --(
          BREAK
          WHILE (0 = 0)
          BEGIN --(
                    SELECT @RoleID_in = SUBSTRING(@UserRoles_in, 1, CHARINDEX(',', @UserRoles_in+',') - 1))
                   else   -- need set the @cnt to ZERO! as per oracle procedure
                           set @cnt = 0
                   IF ( @cnt = 0 )
                   BEGIN
                   END
                  END
             END --)
     END --)
     close csr
DEALLOCATE csr
GO
mironCommented:
also, make cursor look more like sql server
DECLARE @cnt                                      INT
     OPEN csr
     WHILE (@@FETCH_STATUS = 0 )
     BEGIN --(
          WHILE (0 = 0)
          BEGIN --(
                           set @cnt = 0
                   IF ( @cnt = 0 )
                   BEGIN
                   END
                  END
             END --)
     END --)
     close csr
DEALLOCATE csr
GO
mironCommented:
-- correction
DECLARE @cnt                                      INT
     OPEN csr
     BEGIN --(
          WHILE (0 = 0)
          BEGIN --(
                           set @cnt = 0
                   IF ( @cnt = 0 )
                   BEGIN
                   END
                  END
             END --)
     END --)
     close csr
DEALLOCATE csr
GO
mironCommented:
-- correction
DECLARE @cnt                                      INT
     OPEN csr
     BEGIN --(
          WHILE (0 = 0)
          BEGIN --(
                           set @cnt = 0
                   IF ( @cnt = 0 )
                   BEGIN
                   END
             END --)
     END --)
     close csr
DEALLOCATE csr
GO
mironConnect With a Mentor Commented:
-- correction
DECLARE @cnt                                      INT
      OPEN csr
      BEGIN --(
           WHILE (0 = 0)
           BEGIN --(
                     SELECT @RoleID_in = SUBSTRING(@UserRoles_in, 1, CHARINDEX(',', @UserRoles_in+',') - 1 )
                    if (  isnumeric( @RoleId_in ) = 1 )
                            set @cnt = 0
                    IF ( @cnt = 0 )
                    BEGIN
                                 INSERT INTO  error_report VALUES( 'ObjectACL' , '0' , 'UserRoles refering to Non-exing Role : ' + CAST(@RoleID_in AS VARCHAR) )
                    END
              END --)
      END --)
      close csr
 DEALLOCATE csr
mironCommented:
do you have any other questions
Hi, guys, I really appreciate your help and input.
Have a question..
Do I still need to put the below statement. I didnt see this in oracle procedure.
                            set @cnt = 0
Never mind, I guess I need the above statements.
I will test this with some more cases just to make sure. Thanks a lot guys.
