ok i need help on install water cooling system for vga card hehe plz help!
it water cooling block bfg 6800 ultra card i just want to know what i need in parts to run only the video card with water cooling system?  links parts anything! and how to make sure to test it right before i use it. yes i know i'm taking a chance but if done right thier should be no problems. really i'm just looking for something easy to hook it up to with out buying a ton of parts lol.  thanks i don't know what to  put for points on how hard.
 i seen how to piece 1 to gething but i was hope in to finding something easy and small like something fit in a bay window on my computer. i did not want  to buy ten part just for the card if i can help it!
okie1972
okie1972
  • 3
  • 2
Dynamic1Commented:
Hard I modded a Zalman to fit my 6800GT I will look around for you. The holes around the card are super small half what the 9800 Pros were. I drilled the PCB which takes alot of balls on a $500 card but it worked. I will get right back to you with waterblocks.
Dynamic1Commented:
http://www.voyeurmods.com/index.php?action=item&id=1016&prevaction=item&previd=981&prevstart= Here is a Danger den block. Best on market and cools ram alsolet me know if you want more.
Dynamic1Commented:
http://www.dangerden.com/ here is the install info
Protect Your Employees from Wi-Fi Threats
As Wi-Fi growth and popularity continues to climb, not everyone understands the risks that come with connecting to public Wi-Fi or even offering Wi-Fi to employees, visitors and guests. Download the resource kit to make sure your safe wherever business takes you!
okie1972Author Commented:
hm it has the block on it i need the other stuff  i think hehe but should i change the block on it ? i show u the card
 UPGRADE YOUR BFG GeForce™ 6800 Ultra OC™ TODAY!
BFG GeForce™ 6800 Ultra OC™ GPU
with Water Block  This card will feature a water block instead of a GPU fan for those wanting to purchase or who may already have an existing liquid-cooled PC system. Easily hooked up to any existing 1/4” tubing system or to 3/8” tubes with the included adapters, this card runs cool and silent.  BFG Tech is proud to offer their true lifetime warranty on this graphics card.  (Card with water block requires internal or external water cooled system, sold separately
thanks for the help
CallandorCommented:
If you need to look at a few watercooling systems and how they are installed, take a look here: http://www6.tomshardware.com/cpu/20040920/index.html
Join & Write a Comment
Cloud Class® Course: CompTIA Healthcare IT Tech
This course will help prep you to earn the CompTIA Healthcare IT Technician certification showing that you have the knowledge and skills needed to succeed in installing, managing, and troubleshooting IT systems in medical and clinical settings.
  • 3
  • 2
