need help using a loop and switch statement
hey jkr
i am working on that assignment still and i am trying to use a loop to control the program.  I cant get it to go inside my switch statment and pull out the information.  the user starts out with 1000$ and it is to keep running until the user runs out of money or desides to quit.  any help you can give me i will appreciate hopefully you can read what i was tryen to do.
thanks
ted
#include <iostream>
#include <ctime>
#include <cstdlib>
using namespace std;
int main(){
int Dice1        = 0;
int Dice2        = 0;
float Bet        = 0;
int Point        = 0;
int DiceNum1     = 0;
int DiceNum2     = 0;
int SumOfDice    = 0;
float TotalMoney = 1000;
int Counter = 1;
      cout << "Welcome to CRAPS\n\n" << "You have $1,000 dollars\n" << "Please Place A Bet!!\n" << endl;
      cin >>  Bet;
srand(time(0));
Dice1 = 1 + rand() % 6;
Dice2 = 1 + rand() % 6;
SumOfDice = Dice1 + Dice2;
while(TotalMoney > 0)
Counter = Counter++;
switch(SumOfDice){
case 2:
      if(Counter == 1){
      TotalMoney = TotalMoney - Bet;
      cout << "SORRY!! You did not win......:( PLEASE TRY AGAIN!!" << endl;
break;
      else if(Counter > 1){
      cout << "You did not roll your POINT!! PLEASE ROLL AGAIN!!!" << endl;
break;
case 3:
      if(Counter == 1){
break;
break;
case 4:
      if(Counter == 1){
      cout << "Your Point is Set at " << SumOfDice <<" Please roll again" << endl;
break;
      TotalMoney = TotalMoney + Bet;
      cout << "WINNER!!! You rolled your POINT of " << SumOfDice << " You Just won " << Bet <<" Dollars" << endl;
break;
case 5:
      if(Counter == 1){
break;
break;
case 6:
      if(Counter == 1){
break;
break;
case 7:
      if(Counter == 1){
      cout << "WINNER!!! You rolled a " << SumOfDice << " You Just won " << Bet <<" Dollars" << endl;
break;
      else{
break;
case 8:
      if(Counter == 1){
break;
break;
case 9:
      if(Counter == 1){
break;
break;
case 10:
      if(Counter == 1){
break;
break;
case 11:
      if(Counter == 1){
break;
      else{
break;
case 12:
      if(Counter == 1){
break;
break;
tedschnieders
tedschnieders
  • 7
AxterCommented:
It's not entering your switch statement because of your while loop
There's no way for this loop to exit.
AxterCommented:
If you want your switch statement to be inside the while loop, then you need to add start and end braces{}
Example:
            switch(SumOfDice){
            case 2:
                  if(Counter == 1){
                        break;
                        break;
AxterCommented:
The case 8 section is missing an end brace.
      case 8:
            if(Counter == 1){
                  break;
                  break;
And case 12 is also missing an end brace.
AxterCommented:
Actually, case 12 is missing a start and end brace.
Also case 10 is missing a start brace.
AxterCommented:
Here's code with the corrections:
int main(){
      int Dice1        = 0;
      int Dice2        = 0;
      float Bet        = 0;
      int Point        = 0;
      int DiceNum1     = 0;
      int DiceNum2     = 0;
      int SumOfDice    = 0;
      int Counter = 1;
      cin >>  Bet;
      srand(time(0));
            switch(SumOfDice)
            case 2:
                  if(Counter == 1){
                        break;
                        break;
            case 3:
                  if(Counter == 1){
                        break;
                        break;
            case 4:
                  if(Counter == 1){
                        break;
                        break;
            case 5:
                  if(Counter == 1){
                        break;
                        break;
            case 6:
                  if(Counter == 1){
                        break;
                        break;
            case 7:
                  if(Counter == 1){
                        break;
                  else{
                        break;
            case 8:
                  if(Counter == 1){
                        break;
                        break;
            case 9:
                  if(Counter == 1){
                        break;
                        break;
            case 10:
                  if(Counter == 1){
                        break;
                        break;
            case 11:
                  if(Counter == 1){
                        break;
                  else{
                        break;
            case 12:
                  if(Counter == 1){
                        break;
                        break;
      return 0;
AxterCommented:
You should also add a break statement after each else-if condtion statement.
tedschniedersAuthor Commented:
how would i keep track of the money i can't do it in the switch statement because it keeps subtracting it til it equals 0 or it just keeps looping if it is adding
AxterCommented:
In looking at your code, it looks like you also need to move the while loop much higher in your code, so as to include the random input and the user input.
Free Tool: Subnet Calculator
The subnet calculator helps you design networks by taking an IP address and network mask and returning information such as network, broadcast address, and host range.
  • 7
