Replace parts of string.
I have a string like this
strSearchData = "This is $!$text$!$. Here is some more $!$text$!$ for you to read."
Next I have an array
myArray(0) = "<B>"
myArray(1) = "</B">"
myArray(2) = "<I>"
myArray(3) = "</I>"
What I need to do is replace the first instance of $!$ in strSearchData with the value of myArrya(0)
Then I want to replace the second instance of $!$ with the value of myArray(1)
Replace the third instance of $1$ with the value of myArray(2)
and so on.
How do I do this.
CUTTHEMUSIC
CUTTHEMUSIC
  • 4
  • 4
  • 3
Hans LangerCommented:
HI,
you want to do this just for this phrase  or you need a generic code ?
CUTTHEMUSICAuthor Commented:
I need code that searches a string for $!$ and replaces it with the corresponding array value. The $!$ is not always around the word "text" it could be around any word.
you mean,
must result:
This is <b>text</b>. Here is some more <i>text</i> for you to read ??
Get expert help—faster!
wguerramCommented:
Try this:
Dim strSearchData = "This is $!$text$!$. Here is some more $!$text$!$ for you to read."
        Dim myArray(3) As String
        myArray(0) = "<B>"
        myArray(1) = "</B>"
        myArray(2) = "<I>"
        myArray(3) = "</I>"
        Dim i As Integer
        For i = 0 To myArray.Length - 1
            strSearchData = Replace(strSearchData, "$!$", myArray(i), , 1)
        Next
        MsgBox(strSearchData)
Gerente
That is the correct result.
Ok, Then, you can try  the code of wguerram.
GL
mguerram
Your code ouputs this
This is <b>text</b>$!$. Here is some more $!$<b>text</b>$!$ for you to read
Its work fine for me.
wguerramCommented:
It's weird i just copy and paste it form my program and the output is:
This is <b>text</b>. Here is some more <b>text</b> for you to read
Copy your code exactly as you have it your program to take a look at it.
Sorry, I had a typo when I integrated it with my code.
Thanks for the help.
wguerramCommented:
You're welcome
Join & Write a Comment
Free Tool: IP Lookup
  • 4
  • 4
  • 3
