Need help with Paint problems with .NET control (PictureBox)
I have a simple application where I'm using GDI+ objects to draw text onto a PictureBox. In the form's Paint method, I've got a call to redraw the text and that works fine when you move a window through the PictureBox.
However, if you move another window on top of the PictureBox, then switch back to my application, the PictureBox redraws that area to the default background colour after my form paint code runs.
What is the proper way to make sure that a control gets repainted when needed?
tma050898
tma050898
  • 6
  • 2
  • 2
  • +2
Mikal613Commented:
autoredraw = false
tma050898Author Commented:
Where exactly is this property? I don't see any property having to do with drawing on the PictureBox property list.
Mikal613Commented:
on the form
iboutchkineCommented:
.NET does not have autoredraw property. VB6 does
When I looked at  he other person's bio, I kinda figured it was a vb thing. Hopefully, someone here will know the answer for .NET. (Not sure if it matters in terms of winforms, but I'm using Managed C++).
Bob LearnedCommented:
What does the code for the Paint event look like?
Bob
private: System::Void Form1_Paint(System::Object *  sender,
                                                   System::Windows::Forms::PaintEventArgs *  e)
  PaintText();
protected: System::Void PaintText()
  if (textToDisplay)
    // Create the font that will be used.
    System::Drawing::Font* font =
      new System::Drawing::Font(S"Times New Roman",
        Convert::ToSingle(fontSize), FontStyle::Regular);
    // Create a Graphics object from the picture box
    Graphics* g = picText->CreateGraphics();
    // Clear the picture box using a white background so that
    // the gradient and hatch text shows up best
    g->Clear(Color::White);
    // Measure the user-supplied text
    SizeF textSize = g->MeasureString(textToDisplay, font);
    // Create the GDI+ brush
    Brush* brush;
    if (TextStyle::Hatch == style)  // if the user selected Hatch
      // GDI+ supplies a HatchBrush object.
      // I'm using the built-in "cross hatch" pattern
      brush = new HatchBrush(HatchStyle::Cross, primaryColour, secondaryColour);
    else if (TextStyle::Gradient == style) // if the user selected Gradient
      // Instantiate a LinearGradientBrush object.
      // I'm using the built-in "forward-diagonal" gradient
      RectangleF* rect = __nogc new RectangleF(PointF(0, 0), textSize);
      brush = new LinearGradientBrush(*rect,  primaryColour, secondaryColour,
                                                        LinearGradientMode::ForwardDiagonal);
    // Now that we have a brush, simply draw the text using DrawString!!
    g->DrawString(textToDisplay, font, brush,
                          (picText->Width - textSize.Width) / 2,
                          (picText->Height - textSize.Height) / 2);
Use the Graphics from the e.Graphics argument (persistent), instead of the CreateGraphics method (non-persistent).
Bob
Bingo. Here's what I did (for future searches of this help)
1) I changed my button routine to the following
  * setup some internal display variables
  * call picText->Invalidate();
2) Added an event handler for the PictureBox control's (picText) Paint event
3) Moved the form's paint code (that painted the picText control into the picText::Paint method
4) Per "TheLearnedOne's" advice, I then used the PaintEventArgs::Graphics object
Works perfectly. Thanks much.
One last question. Should I be disposing of these objects at some pt (via obj->Dispose) ?
Mike TomlinsonMiddle School Assistant TeacherCommented:
To answer your last question:
If YOU create a graphics, brush or pen using CreateGraphics or the NEW keyword, then YOU need to dispose of it.  If you use the supplied graphics in the "e" argument then you DO NOT need need to dispose it.
~IM
So in this case I should be releasing the Font, then. Thanks!
The new generation of project management tools
With monday.com’s project management tool, you can see what everyone on your team is working in a single glance. Its intuitive dashboards are customizable, so you can create systems that work for you.
  • 6
  • 2
  • 2
  • +2
