theexxx
NETWORK WITH 3 PCS NOT USING 4 NIC PROBLEM
AT MY HOME I HAVE THE FOLLOWING NETWORK (WITH OUT AN HUB) all pc has win xp pro
Pc B Pc A Pc C
1gb nic ------ 1gb nic |
192.168.0. 192.186.0.1 |
100mb nic ----------- 100mb nic
192.196.0.3 192.168.0.2
ADSL MODEM
SHARED
PC B HAS AS GATEWAY PC A WITH ADDRESS 192.168.0.1
PC C HAS AS GATEWAY PC A WITH ADDRESS 192.168.0.3
PC A SEES PC B AND PC C IN LOCAL NETWORK Network Neighbor
PC B SEES ONLY PC A IN LOCAL NETWORK Network Neighbor
PC C SEES ONLY PC A IN LOCAL NETWORK Network Neighbor
PC B IS ABLE TO GO ON INTERNET
PC C IS NOT ABLE TO GO ON INTERNET
IS NOT POSSIBLE TO MAKE A BRIDGE ON PC A BETWEEN THE TWO NIC
(I GET A MESSAGE THAT SAYS THAT TO MAKE A BRIDGE I NEED 2 LAN NETWORK OR INTERNET NETWORK
THAT ARE NOT SHARED)
ANY CLUE HOW TO HAVE ALL PC THAT SEE EACH OTHER AND PC C GOING TO INTERNET TOO ??
Pc B Pc A Pc C
ADSL MODEM
SHARED
You need a hub. Bottom line.
why i just needan hub ?
explain me pls
explain me pls
i don't understand your drawing.. do any of the computers have more than one network card?
What is the ADSL shared modem? is it a Cable/DSL router?
pc a has 2 nic card
adsl modem is an usb modem that provide internet connection shared to other 2 pc
my adsl modem is seen as network connection and it has ics..
both other niic has not ics..due it setted on the modem....
i don't want to use a hud due i must be 1gb hub...
can i disable ics ..bridge the two network and after enable again ics ?
what do you think ?
what do you think ?
solved as described in previous post
thanks for help
exx
thanks for help
exx
I believe the reference is to "my" previous post. I was the only one that posted a suggested solution..
