AnthonyFee
What spec of a stepper motor would i need for building a small robot moving at a speed of between 2 and 4 meters per second.
What spec of a stepper motor would i need for building a small robot moving at a speed of between 2 and 4 meters per second. Pretty Urgent!
Um... This is MySql Database Category.
Probably not the right group for this question, but, in the interest of helping out, try
http://www.cs.uiowa.edu/~jones/step/
hth
Mike
hth
Mike
I've seen a full sized jet liner converted to remote control (crash testing a new fuel - complete failure if I remember right). On that scale, this is 'small' :P.
s46.
s46.
Another thought DK... with that much metal around you could probably just weld the motor case to the chassis and use the whole body as a heat sink...
s46
s46
I think I should get all the points - nobody else made a suggestion half as daft as mine!
Alternatively, you may consider that this question hasn't yet been adequately answered and should be deleted with refund, but if the silly sod gave tmcguinness the info he needed I wouldn't have fel the need...
s46.
s46.
I'd say give solution46 twice the offered points and send a rude message to "AnthonyFee" telling him/her just what he did wrong to post an inherently impossible question (error 1) in the wrong forum (error 2) and then abandon it (error 3), and that he's luck not to be losing the offered points for *each* violation !
cheers, DcpKing!
cheers, DcpKing!
I say just let it drop. Solution46 and DcpKing have already gotten their money's worth out of the question! :) (no offense, guys... I _liked_ your suggestions) and I sure didn't do anything worth points.
Yeah... one of the more amusing questions I've participated in! Let it be.
s46.
s46.
well lads as ye can see i was laughing to myself inside in the computer lab here so i thought ye all desrved a share in the points. haven't looked at the account for a while but just think... if i had replied ye might not have had this time to bond with eachother! anyway thanks to all who did attempt to answer the question( tmcguiness) and to the others... continue the good work! Cya!
no probs bud! Glad we could all help you with your robot design :).
p.s. Who's up for joinging together for a 'Robot Wars' team - I think we have a winner!!!
