jewee
Problem with search using maps..HELP!
In the following code, I have a map with a string as the key and a corresponding string. I also have a vector of strings. What I am trying to do is to search through the map for the vector string, if found, then store the corresponding string to a buffer.
There is a problem with how I implemented the searching capability since it is true every time.
Also, outside of this for loop, I need to check if a particular file exists within the vector.
td::string ViewForm::createConfigFile (std::map <std::string, std::string>& groupFiles,
std::vector <std::string>& signalList)
bool groupFileMatch = false;
std::string fileScript;
std::string configFile = "";
std::vector <std::string>::const_itera tor signalIt;
std::map <std::string, std::string>::const_iterat or mapIt;
fileScript = "cat ";
if(!signalList.empty())
groupFileMatch = true;
for (signalIt = signalList.begin(); signalIt != signalList.end(); signalIt++)
mapIt = groupFiles.find(signalIt-> c_str());
if (mapIt != groupFiles.end())
fileScript += mapIt->second + " ";
//Special case.
//For button7, the NA1 config file needs to be concatenated for all cases.
//If a NA1 file exists, this needs to be concatenated to the config file
printf("IN CONFIG...\n");
mapIt = groupFiles.begin();
mapIt = groupFiles.find("NA1");
//Special case.
Just checked it...The map does contain all values and is returning the first value even though it does not match.
I do not necessarily need to check and see if it is a match...The string values in the vector will match up with the keys in the map. Therefore, there will always be a match.
I guess I am just trying to understand the find function. The iterator should return the position of the key entered.
mapIt = groupFiles.find(*signalIt)
instead of
Apart from that, the code looks OK. Try calling
void dump_map std::map <std::string, std::string>& theMap){
for ( mapIt = theMap.begin(); mapIt != theMap.end(); ++mapIt) {
std::cout << mapIt->first << "\t" << mapIt->second() << std::endl;
to see what the map actually contains before looking up values.
