java.sql.Connection.TRANSACTION_READ_UNCOMMITED doesn't work in Oracle?
Hello experts,
Using JDBC to connect to an oracle db.
when I set the transaction isolation level for my connection object as:
myConnection.setTransactionIsolation(Connection.TRANSACTION_READ_UNCOMMITED);
then run time error said:
SQLEXception:
Message: READ_COMMITED and SERIALIZABLE are the only valid transaction levels
Does that mean I can't use TRANSACTION_READ_UNCOMMITED level with Oracle???
dttaiAsked:
andrewstCommented:
Yes - Oracle does not support READ UNCOMMITTED.
vn77Commented:
Oracle only supports READ_COMMITED and SEARIALIZABLE as being very obvious in your error msg.
To see it for yourself, you can read this chapter from Oracle doc
https://cwisdb.cc.kuleuven.ac.be/ora10doc/appdev.101/b10795/adfns_sq.htm#1007214
In case the link doesn't work, you can go to Oracle site and find the followng document:
Oracle® Database Application Developer's Guide - Fundamentals
10g Release 1 (10.1)
Read chapter 5 (pretty short)
G'luck,
vn
Oracle Database
