summer_soccer
SUSE 9.2 wireless lan setup problem on DELL 600m with 1350 WLAN mini-PCI card
Dear all,
I have spent an large amount of labor trying to solve this dell 600m laptop wireless card configuration problem but have not succedded yet. So here I am to seek your help.
I have installed SUSE 9.2 professional version on my newly purchased DELL 600m laptop. This laptop has intregrated a BroadCom 1350 WLAN min-PCI card on board. I googled the Internet and found people suggesting to install ndiswrapper. So I downloaded the ndiswrapper and installed it. Then I downloaded the DELL's Windows XP driver for this 1350 card: bcmwl5 and bcmwl5a. Then I modprobe ndiswrapper; iwconfig the card; ifconfig wlan0 up. Now the configuration files are as follow:
ifconfig:
eth0 Link encap:Ethernet HWaddr 00:0F:1F:C4:77:D6
inet6 addr: fe80::20f:1fff:fec4:77d6/6 4 Scope:Link
UP BROADCAST NOTRAILERS MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:11
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:68 errors:0 dropped:0 overruns:0 frame:0
TX packets:68 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:4916 (4.8 Kb) TX bytes:4916 (4.8 Kb)
wlan0 Link encap:Ethernet HWaddr 00:0B:7D:0A:71:C2
inet addr:128.239.186.122 Bcast:128.239.191.255 Mask:255.255.248.0
inet6 addr: fe80::20b:7dff:fe0a:71c2/6 4 Scope:Link
UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1
RX packets:8584 errors:0 dropped:0 overruns:0 frame:0
TX packets:7 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1009193 (985.5 Kb) TX bytes:1024 (1024.0 b)
Interrupt:7 Memory:fafee000-fafeffff
iwconfig:
wlan0 IEEE 802.11g ESSID:"W-M_Wireless" Nickname:"linux"
Mode:Managed Frequency:2.462 GHz Access Point: 00:01:F4:6B:0F:4D
Bit Rate=54 Mb/s Tx-Power:25 dBm
RTS thr=2347 B Fragment thr=2346 B
Encryption key:off
Power Management min timeout:0us mode:All packets received
Link Quality:100/100 Signal level:-47 dBm Noise level:-256 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:4276 Missed beacon:0
ndiswrapper -l:
Installed ndis drivers:
bcmwl5 driver present, hardware present
bcmwl5a driver present, hardware present
Then I changed to load the ndiswrapper module at boot, and reboot the system.
At the booting time, it showed the wlan0 card is detected, but the system failed to bring up the mandatory device for wlan0. After logging into KDE, the wireless lan is not accessible. Can anybody help me solve this problem? Many many thanks.
By the way, does anybody why I cannot copy files from SUSE Linux partitions to any windows XP partitions?
Best,
Soccer
ifconfig:
Interrupt:11
iwconfig:
Encryption key:off
ndiswrapper -l:
Best,
Soccer
http://www.techspot.com/vb/topic7403.html
"Red Hat's kernel is compiled by default so that it has nearly everything in modules. You can install ntfs module with insmod ntfs from command line. You can also check which filesystems are supported with cat /proc/filesystems."
How are you making out summer?
I am winning each battle, one at a time.
Wireless loads and works wonderfully. I am only using ONE of the 2 inf files. bcmwl5.inf is all I am loading. I would try removing the second driver you are trying to load. I think the command is
ndiswrapper -e bcmwl5a.inf
Then it would help to see the results of
iwlist scan
I can read the NTFS partitions but I cheated and grabbed an RPM to it. I've recompiled to kernel before, but just am not ready to go there yet.
iwlist scan
Thanks Mike. I tried a lot of things out, finally I resolved this problem luckily. I don't know why it was resolved:)
What I did is: first ifdown eth0, then ifdown wlan0, then ifup wlan0. The wireless card worked then. Thanks for your help.
IF I use that to ping an internet IP, I get no reply yet.
As per the HDD Qs.
I am using the New Fedora 3 Core. Dual boot on my Dell Inspiron 5150. Other OS is XP PRO.
XP will NOT read my Linux partitions NOR will my Linux read XP's NTFS. I do not believe the kernel supports it. I tried to mount the NTFS Part just for the fun of it and received an error to the effect the kernel did not support NTFS Partitions. Tried to mount a FAT32 Part and the same type error.
Last time I played with Redhat (approx ver 5) I know I made Linux read a FAT32 Partition, but I may have installed something to do so. I just cant remember at this point. I'll be heading there in time so maybe we can share the req info whoever gets there first?
WHY did you load bcmwl5 and bcmwl5a?
When I looked at the inf files, bcmwl5a appeared to be a win95 inf file.
MAYBE your load problem is due to this?????
I am only loading bcmwl5.
********** bcmwl5 file beginning **********
;; bcmwl5.inf
;; Copyright 1998-2003, Broadcom Corporation.
;; All Rights Reserved.
;; This is UNPUBLISHED PROPRIETARY SOURCE CODE of Broadcom Corporation;
;; the contents of this file may not be disclosed to third parties, copied or
;; duplicated in any form, in whole or in part, without the prior written
;; permission of Broadcom Corporation.
[version]
Signature = "$Windows NT$"
Class=Net
ClassGUID = {4d36e972-e325-11ce-bfc1-0
Provider = %V_BCM%
Compatible = 1
DriverVer=06/25/2004, 3.40.73.0
CatalogFile=BCM43XX.CAT
[Manufacturer]
%V_BCM% = BROADCOM
********** bcmwl5a file beginning **********
;; bcmwl5.inf
[version]
Signature = "$Windows 95$"
Class=Net
Provider = %V_BCM%
Compatible = 1
CatalogFile=BCM43XXA.CAT
[Manufacturer]
%V_BCM% = BROADCOM
BASED on what I saw in those inf files I have been loading the bcmwl5.inf using ndiswrapper. I assumed the bcmwl5a was a Win9x version fo the driver. Maybe that is a problem? I could be wrong, I am really just guessing but it may be of use to you?
DOES iwlist show you yor Wireless LAN at all?
Try this command, I do not see your results above.
iwlist scan
This will have the adapter scan for wireless networks.
My driver loads on boot. iwlist shows me my WAP and the other WAP clients. I can see the MACs of other PC's and my WAP. I can ping to the WAP and LAN PC's. But still cant get a packet to the internet.
Hope some of this helps!
Mike
