How to read Row value after using Select method for datatable
I am using a select method on a datatable to find a certain row. I am finding the  datarow using the following code. This works fine
Dim SiteCurrencyDescriptionRow() As DataRow
            SiteCurrencyDescriptionRow = dtCurrency.Select("chCurrencyCd =" & "'" & CType(dtSiteCurrencyCode.Rows(1)("chCurrencyCd"), String) & "'")
How do I access the 1st coloumn value of the sitecurrencydescriptiondatarow.
I am doing something like this but it dont work.
txtsitecurrency.text =  ctype(SiteCurrencyDescriptionRow.getvalue(0), string)
where am i going wr
anwarmirAsked:
RonaldBiemansCommented:
txtsitecurrency.text =  SiteCurrencyDescriptionRow.item(0)
anwarmirAuthor Commented:
Hi I cant use Item as there is an error
"Item is not a member of system array"
A sorry ,
txtsitecurrency.text =  SiteCurrencyDescriptionRow(0).item(0)
Visual Basic.NET
