Rediffmail behaves weird from system to system...help?
I have a rediffmail account.
My system OS is windows XP professional(desktop).
After system restoring few days back, I am not able to access my rediffmail account. everytime i enter the username and password and click login, it says, "your session in invalid/timed out. Please login again".
  I have a laptop with the same OS, but I am able to access my rediffmail account in this system without any problem.
 can anyone suggest me what might be the problem?
Appreciate your advice.
regards
vijisu.
vijisuAsked:
sunray_2003Commented:
Hi vijisu,
Have you tried to system restore to a forward time .. it is a 2 way process and see if that would solve
Have you tried to delete your rediffmail account (just the email account) and create it again to see if that would help
Can you check if the account settings on both the desktop and laptop for this account in OE is the same ?
Try to temporarily disable anti-virus , firewall in your desktop and see if that would help.
Try to increase the server timeouts for rediffmail account in OE going to tools > accounts > properties > advanced settings and check if that would help
alshahnazCommented:
Hi buddy,
Open the internet browser
go to Tools -->Internet Options.
Under temproary internet files region clcik Delete Cookies  and Delete Files
then clik ok
Now it must be working fine.
rgds
Shan
vijisuAuthor Commented:
I have tried deleting cookies and files in the temp. internet files. but still it doesn't work. But it works in Linux(installed in the 2nd Hard Drive) and also the laptop which has the same configuration as my desktop.
 very confusing...!!!!
Cloud Class® Course: Python 3 Fundamentals
This course will teach participants about installing and configuring Python, syntax, importing, statements, types, strings, booleans, files, lists, tuples, comprehensions, functions, and classes.
viji
have you checked all the suggestions in my first comment
alshahnazCommented:
hi,
i dont think its a big issue.its something small in internet settings.i am sure about it ok
try this both
1)go to Tools -->Internet Options and click the security tab
Then click Default level button.
then
2)go to Tools -->Internet Options and click the Advance tab and click Restore Defaults button.
Then go to command prompt
type
ipconfig /flushdns
hope this helps
Shan
hi alshahnaz, i have tried 1 and 2 and /flushdns. But could not get it. However, Thanq for your advice.
hi  sunray_2003, i have shoutdown my firewall(zoneAlarm) temporarily, and it did work.....Just checking how come firewall is the problem for rediffmail?
Thanq for  your help.
Did you say you are checking your email account (rediffmail) going to rediffmail.com or using email client ?
If it is webmail then try to turn ON zonealarm and check using a different browser and see what happens
Email Software
