Solved
Is it worth trying to fix "Printer not Responding"  and "No connection" type problems with printers.
Posted on 2005-03-04
Last Modified: 2010-04-12
My basement is full of dead printers.  Many are quite new, including several HP’s.  Is there any point in trying to resuscitate those with connection problems?  The printer is working fine and then suddenly the computer can’t send data to it.  I have customers who could use these printers, but only if it’s not too time consuming for me to make them work.  Also they have to keep on working or I’ll be getting calls to fix them.  Any opinions on whether it’s worth my time to try and get them working?
Al
Question by:alanlsilverman
3 Comments
LVL 93
Accepted Solution
by:
nobus earned 600 total points
it depends. That is  the answer.
You candivide  the problems into 2 sections : mechanical and electronic.
So you can take a logic board from a mechanical problem printer (MPP) and install it into one with an electrical problem (EPP)
you can also take parts out of one with a dead board, and repair the one with mechanical problems.
Both cases would give you a good product again.
It depends on the time you will need to replace the boards and parts in order to say if it is worth your time and effort, and on how valuable is your time.
LVL 39
Assisted Solution
by:hdhondt
hdhondt earned 400 total points
I agree with nobus.
However, especially with networked printers, I can also think of a number of reasons why a perfectly good printer may stop responding if someone changes network or driver settings. You really need to take each case on its own.
Author Comment
by:alanlsilverman
Al
We value your feedback.
This seems to be a very common error related to the Samsung printer driver. First, this is the error we're talking about: Log: System Type: Error Event: 7000 Agent Time: 3:37:24 am 22-Apr-09 Event Time: 6:07:24 pm 21-Apr-09 UTC Source: Se…
Printers have changed substantially in the last 30 or so years, not just in technical capabilities but in cost and usage as well.  Printers were originally used for interfacing with the operator, not necessarily for printing copy or pictures. In …
In an interesting question (https://www.experts-exchange.com/questions/29008360/) here at Experts Exchange, a member asked how to split a single image into multiple images. The primary usage for this is to place many photographs on a flatbed scanner…
Please read the paragraph below before following the instructions in the video — there are important caveats in the paragraph that I did not mention in the video. If your PaperPort 12 or PaperPort 14 is failing to start, or crashing, or hanging, …
Suggested Courses
616 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
