Problem with socket code...help!
500 points for anyone who helps me with this!  I am connecting to a server.  I was told to use asynchronous sockets when creating this api.
Here is my code, it is actually not receiving anything from the server.
use IO::Socket;
my $socket = new IO::Socket::INET (
                                  PeerAddr => '10.0.0.2',
                                  PeerPort => '2222',
                                  Proto => 'tcp',
die "Could not create socket: $!\n" unless $socket;
   #GHeader (24B):
      #TaskID = 0xD0 - constant
      #MsgSize = 40 - constant
      #Client ID = 0;
      #Status = 0;
      #Command - Get number of stats counters = 0x65
      #Reserved = 0;
   #GCPayload (16B):
         #ChannelNum = 0
         #Refresh = 0 (no refresh)
         #1st Count Address = 0 ???
         #Num of counters -
@requestBytes=(0xD0, 0x28, 0x00, 0x00, 0x65, 0x00, 0x00, 0x00, 0x00, 0x01);
$requestMsg = pack 'C*',@requestBytes;
while($socket->connected) {
  $socket->write($requestMsg);
  #Retrieve only header
  $socket->read($buffer,24);
  my ($taskid, $size, $clientId, $status, $command) = unpack "C4 C4 C4 C4 C4", $buffer;
  if ($size >= $request_size)
      $socket->read($buffer,$size);
     my ($channelNum, $refresh, $ctAddress, $counter1, $counter2) = unpack "C4 C4 C4 C8 C8", $buffer;
     print "channel num $channelNum\n";
  else
     print "ERROR\n";
  #Parse data -
  #Header:
  #Payload - each non-counter field 4 bytes = total length - 4*4+8*numCounter)
  sleep(1);
jewee
jewee
  • 4
  • 2
ozoCommented:
It works for me, are you sure the server is sending anything?
Are you sure you want unpack "C4 C4 C4 C4 C4"?
ozoCommented:
is the same as
unpack "C20"
or
unpack "CCCCCCCCCCCCCCCCCCCC";
which returns 20 fields of which you only assign the first five.
Did you mean unpack "A4 A4 A4 A4 A4" ?
jeweeAuthor Commented:
The header consists of 24 bytes, 4 bytes per field.
However, i believe I may want to implement asynchronous sockets since there are other processes connected to this as well?
We value your feedback.
ozoCommented:
That sounds like
unpack "a4"x6,$buffer;
or
unpack "A4"x6,$buffer;
depending on what you'd want to do with any space or null padding
But it sounds like i need to use asynchronous sockets, however, I have only heard about asynch sockets in C++, not in perl.
ozoCommented:
As described in
perldoc perlipc
Perl can handle asynchronous sockets in the server as C++ does by forking a slave server to handle each client request.
The client could also fork multiple processes if it wants to deal with multiple servers.
It could also use
select RBITS,WBITS,EBITS,TIMEOUT;
to check which of multiple servers has a socket ready for input or output
Free Tool: Site Down Detector
  • 4
  • 2
