Rory_W
Linksys Wireless G Adapter card connection problems
I have a Linksys Wireless G Adapter card for my notebook w/ a wireless G Broadband Router and about every 10 minutes the notebook looses the connection and I have to select "repair" to establish another connection. Then it goes for another 10 minutes. It is annoying especially when you are downloading. Any help is appreciated.
If that helps I can give the settings that I had to adjust on the usr router.
In the "Remote Managemant" section I had to disable everything except "Mutlicast Streams". Maybe you can try something similar. You probably won't need remote management anyway, for security reasons.
rindi, what I finally found and not with the help of Linksys was Windows XP and the Linksys program are conflicting. When I shut down the Linksys program in my msconfig file my wireless works fine. So you might try that.
Thanks.
