Nmagsaysay
Remote Desktop Connection RDC kills monitor on remote machine
When i create a VPN and log back into my office i can work fine; i log off fine and kill the VPN. But when i go into the office to work my monitor is not getting a video signal and the only way to get it back up is to do a hard shutdown of the machine. I'm convinced this is directly resultant from the RDC. Please help.
Checked all the power settings. Turned off the monitor before logging in. Tried just disconnecting instead of logging off. Nothing works. Any thinking outside of the box solutions would be helpful.
