Using CFMX 7 and Flash forms - trying to call a javascript from within the form and capture values - help?
I have a fairly simple flash from, and I am trying to have either a link inside the flash form, or outside the flash, execute a javascript that will perform an XmlHTTP request, passing values from inside the flash form.  Here is my code right now (in development, so semi-messy)
var xmlhttp=false;
/*@cc_on @*/
/*@if (@_jscript_version >= 5)
// JScript gives us Conditional compilation, we can cope with old IE versions.
// and security blocked creation of the objects.
 try {
  xmlhttp = new ActiveXObject("Msxml2.XMLHTTP");
 } catch (e) {
  try {
   xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
  } catch (E) {
   xmlhttp = false;
@end @*/
if (!xmlhttp && typeof XMLHttpRequest!='undefined') {
  xmlhttp = new XMLHttpRequest();
// function getfile will perform our request using our created xmlhttp object //
function getfile() {
      // this line refers to our input box named filename //
      document.getElementById('searchResults').innerHTML = "<center><img src='images/pleasewait.gif'></center>";
      var Current = "search.cfm?origincity=" + document.myform.origincity.value + "&originstate=" + document.myform.originstate.value + "&destinationcity=" + document.myform.destinationcity.value + "&destinationstate=" + document.myform.destinationstate.value;
      xmlhttp.open("GET", Current, true);
      xmlhttp.onreadystatechange=function() {
            if (xmlhttp.readyState==4) {
            document.getElementById('searchResults').innerHTML = xmlhttp.responseText;
      xmlhttp.send(null)
</script>
<body>
      <table width="720" cellspacing="0" cellpadding="0" border="1px solid black">
            <TR>
                  <TD>
                        <BR>
                        <cfform name="myform" format="flash">
                              <cfformgroup type="horizontal">
                                    <cfinput name="origincity" label="Origin City"> <cfinput name="originstate" label="Origin State">
                              </cfformgroup>
                                    <cfinput name="destinationcity" label="Destination City"> <cfinput name="destinationstate" label="Destination State">
                              </cfformgroup>
                              <cfinput type="submit" name="Submit" value="Submit" >
                        </cfform>
                  </TD>
            </TR>
      </table>
<div id="searchResults" title="searchResults" style="position:relative; display:block; width:100%;"></div>
</body>
</html>
The object of this is to present the user with a nice clean looking flash form, and instantly pull the results of the search up in a DIV below the flash form.  I want this to appear seamless, and not make the user re-load the flash form each time they search.  I can make this work just fine with a html formatted form, but I want to take advantage of the new CF features!  Is there a way to do this using some type of action scripts, or some javascript magic I can use?
Thanks in advance!
Chris Peterson
LVL 1
JUSTICEAsked:
mmc98dl1Commented:
You should be able to use the actionscript element on the flash form to call the action script command fscommand() - this enables you to interact with javascript on the page.
JUSTICEAuthor Commented:
I am not gonna get any love on this one eh? =)  So, is there any way to communicate from Coldfusion 7 MX's auto-generated flash files to a javascript on the same page?
mmc98dl1Commented:
http://www.moock.org/webdesign/flash/fscommand/
or you can try <cfform name="myform" format="flash" onSubmit="getFile();">
mmc98dl1Commented:
and you will need to change the js references to something like this: document.applets[0].getVariable("origincity.value");
you are my hero! =)
