Solved
how to make icon with transparant parts - MSVC6.0
Posted on 2005-04-27
5
Last Modified: 2013-11-20
I want to make a MFC - dialog based small application with MSVC 6.0 .
I made a bmp-resource. I want now that some parts of it are transparant. I tried to change the black (which I want transparant) to pink , but this didn't worked (so it's not "magic pink").
How can I do what I want to ??
I'm not experienced with photoshop or other "heavy" image-editing programs...
Thanks in advance.
plinius.
Question by:plinius
  • 3
5 Comments
LVL 16
Assisted Solution
by:nonubik
nonubik earned 80 total points
You need to edit the bitmap/icon in some other environment, a "clever" one. Like Adobe or a real image editor. The VC++ 6.0 resource editor is not that smart.
Author Comment
by:plinius
Hmm.. Thanks.
Author Comment
by:plinius
but  I thought bmp doesn't supports transparancy
LVL 2
Accepted Solution
by:
teuntje earned 420 total points
you can search for a library which allows you to set a certain color as transparant (e.g. black).
I think (not sure though) that bcgcontrolbar can do this.
http://www.bcgsoft.com/bcgcontrolbar.htm
grtz
Author Comment
by:plinius
thanks.
maybe I'll try it.
VIDEO: THE CONCERTO CLOUD FOR HEALTHCARE
Modern healthcare requires a modern cloud. View this brief video to understand how the Concerto Cloud for Healthcare can help your organization.
Here is how to use MFC's automatic Radio Button handling in your dialog boxes and forms.  Beginner programmers usually start with a OnClick handler for each radio button and that's just not the right way to go.  MFC has a very cool system for handli…
Introduction: Finishing the grid – keyboard support for arrow keys to manoeuvre, entering the numbers.  The PreTranslateMessage function is to be used to intercept and respond to keyboard events. Continuing from the fourth article about sudoku. …
This video will show you how to get GIT to work in Eclipse.   It will walk you through how to install the EGit plugin in eclipse and how to checkout an existing repository.
Exchange organizations may use the Journaling Agent of the Transport Service to archive messages going through Exchange. However, if the Transport Service is integrated with some email content management application (such as an anti-spam), the admin…
Suggested Courses
Course of the Month16 days, 13 hours left to enroll
862 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
