Power supply fan doesn't work but PC does have power.
Client has a HP Pavillion 734N.  Power supply fan does not come on but the PC does have power and boots up normally.  Could it be anything other than a failing power supply that needs to be replaced?
A.V.
A.V.
2 Solutions
compfixer101Commented:
nope the fan need to be cleaned and oiled but  i don't have time to explain the steps today for i have to get to class i will trun through the steps of fixing this tommorrow  MY DAD's PSu was the same way i didn't realize it until i went back there to plug in something   and i told my dad about it and ghe said that i can try to fix it and so i did and now it works fine
CF101
oldgreyguyCommented:
could just be the fan/or curcuitry...............  just put another Power Suppy in
CallandorCommented:
Don't try to fix the fan in a power supply, unless you are familiar with observing safety precautions with electrical devices.  Opening up a supply can result in damage to the supply, creating a short, and injury to yourself.  You are better off replacing the entire unit.
Free Tool: SSL Checker
Scans your site and returns information about your SSL implementation and certificate. Helpful for debugging and validating your SSL configuration.
J-A-LCommented:
You can buy a fan for the PSU, open the PSU up and replace the fan. Many PSU have a connector that goes to the unit... others are soldered and will have to have the wires reconnected... in the proper color sequence.
Other than that, it's only the fan that has seized and should probably be replaced.
Jeff
at yourtechonline.com
"client" implies that this is your customer... if so... and this is not a shadetree fix it overnite.... whatever......................         why would you spend the time to remove the power supply, pull the fan (unsoldering the two wires... since these power supplies do not use fan coonectors), order a fan for these rather small power supplies, replace the fan, resolder the wires........... and send the unit back to the "client"...............              what are you going to warranty... the fan............. buy a new PS... and give the customer what they deserve..............
apologies to the questioner if my retort seems short.... I spend an inordinate amount of shop time... fixing shadetree fixes.......... and listening to the customers bitch because the had the problem "fixed" by Marvin the wonder tech
hmmmmmmmm, maybe it was FONG the wonder tech
A.V.Lead EngineerAuthor Commented:
LOL....no worries....I just bought a new powersupply :) thanks to all!
CF101    your welcome   i guess
Join & Write a Comment
Cloud Class® Course: Ruby Fundamentals
This course will introduce you to Ruby, as well as teach you about classes, methods, variables, data structures, loops, enumerable methods, and finishing touches.
