Solved
Possible problems with a 250 watt power supply
Posted on 2005-05-11
5
Last Modified: 2011-04-14
Hello everyone.
One of our Dell's has a 250 watt power supply. The following are connected to the mobo:
3.4 GHz P IV
1024 RAM
1 rear fan
1 80 gig hddrive
1 DVD-R/CD-RW
1 64 MB Radeon 9200 AGP
1 64 MB Radeon 9200 PCI
1 external hdrive (USB)
1 PDA Device
1 external USB NIC card
1 optical mouse
Based off the list above, you think this is too much for a 250 watt power supply?  The reason why i am asking this is because occasionally the user's computer freezes and both LED's in the front are not lit.  However, the power supply fan is still running.
Dell support said it had to do with the system going into standby, but i refuse to believe that because standby is disabled! I think occasionally the system cannot handle giving power to the graphics cards.
Plus this problem occurs 2-3 times a month.
What do you experts think?
Thanks.
Question by:carpetflyer
  • 2
  • 2
5 Comments
LVL 7
Accepted Solution
by:
waffleironhead earned 1000 total points
90 watts --------------------------------------------processor
35 watts --------------------------------------------g-card 1
35 watts---------------------------------------------g card 2
40 watts---------------------------------------------ram
25 watts---------------------------------------------hd
30 watts---------------------------------------------burner
2 watts ----------------------------------------------fan
just rough estimates, but you are already over the top....
suggest a new(bigger) power supply
these values were taken from
http://www.jscustompcs.com/power_supply/Power_Supply_Calculator.php?cmd=INTEL
hth
waffle
LVL 3
Author Comment
by:carpetflyer
wow nice find.
Yea my gut instincts was that it was getting a bit overloaded.
I will prob get a 300 watt supply...what do you think?  The user does not play games...this is a business computer so its used for database/web/spreadsheets, etc.
LVL 7
Assisted Solution
by:waffleironhead
the overloading of a power supply can cause issues with the rest of the system, instability,which you saw, and even hardware failure due to poor current, the cost of a new supply versus the cost/headache of dead drives and cards is well worth it IMO.
300 watt should do it. though if you shifted the the usb items to a powered hub it would take some stress off tof the system ps.
hth
waffle
LVL 3
Author Comment
by:carpetflyer
I will go ahead and buy a 300 watt supply. i doubt dell would give us one for free (still under warranty).
Thanks again waffleironhead!
LVL 2
Expert Comment
by:n0de1
Your talking about a Dell PC here.
Do not just go out and buy a PSU from a shop.
You have to make sure it's a Dell PSU as they switch the wires around and you will have wrong voltages going into your motherboard.
Needless to say this will cause damage to most of your components, CPU RAM and any cards installed. Possibel alos that IDE connected devices could be damaged.
Not sure if all Dell models have this issue, but just check the wires with your old PSU to get an idea, you will notice if they are differently mapped out.
We value your feedback.
Basic computer tune-up with little or no hardware upgrades. Giving an old computer a tune-up usually results in a minimal performance gain, but a gain nonetheless. Several times a week, I’m faced with users at work who ask to make their computers…
How do you create a user-centered user experience on your website? And what are some things you should consider in the process?
Finding and deleting duplicate (picture) files can be a time consuming task. My wife and I, our three kids and their families all share one dilemma: Managing our pictures. Between desktops, laptops, phones, tablets, and cameras; over the last decade…
Want to learn how to record your desktop screen without having to use an outside camera. Click on this video and learn how to use the cool google extension called "Screencastify"! Step 1: Open a new google tab Step 2: Go to the left hand upper corn…
Suggested Courses
Course of the Month15 days, left to enroll
578 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
