troubleshooting Question
Problem in Variant Parts
Avatar of srisha
srisha asked on
Delphi
19 Comments1 Solution498 ViewsLast Modified:
Hi all,
I have a strange problem.
I have defined a packed record in Delphi 2005(for .NET) which looks like this:
Type
TAccount = Packed Record
    Case Integer of
    0: (
      Account  : Array of Char;
    1: (
      Currency   : Array of Char;
      Member       : Array of Char;
      Customer : Array of Char;
      Group   : Array of Char;
end;
I have removed the array lengths as it is not supported in .NET in variant records. I have defined var of TAccountNo as say ACNo.
The problem is let say I assign '0123456789' to ACNo.Account, it automatically assign whole of it to first one, Currency and Member,Customer &group are all empty.
Is there any method by which I can split the first part and assign it the second, I mean
 if
ACNo.Account = 0123456789
then Currency = 01
       Member = 23
       CustomerNo = 45678
       group = 9
I have tried with setting the length of array dynamically, it won't work as array is now reference type(If I am correct) and will be stored as pointers of length 16 bytes.
Can anybody help me out?
Unlock 1 Answer and 19 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
