troubleshooting Question
body onload and unload problem..
Avatar of sandsgaucho
sandsgaucho asked on
JavaScript
15 Comments1 Solution1272 ViewsLast Modified:
I need to do the following: When the user tries to close the browser/ perform refresh or navigate to another page, display a confirm box and if the user clicks on CANCEL, the action should be killed.
I  have body tag as follows:
<body leftmargin=0 topmargin=0 marginheight="0" marginwidth="0" bgcolor="#ffffff" onload="closure();ini('<%=npass%>');" onunload="confirmClose">
and my confirmClose is :
function confirmClose() {
var agree=confirm("Sure u want to close/ navigate away?");
if (agree) {
      return true ;
} else {
      return false ;
The problem is that the unload function is simply not being executed... whats stranges is that if I remove the onload functions, it executes fine..
any suggestions ?
TIA
Unlock 1 Answer and 15 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
