troubleshooting Question
System Tray- Applications not Showing up in System Tray
Avatar of davidw8
davidw8Flag for United States of America asked on
Windows XP
7 Comments1 Solution992 ViewsLast Modified:
Each time I restart Windows XP SP2, the apps in the System Tray differ.  Some appear all the time, some apps, like Hotsync.exe, Spysweeper, appear on the System Tray intermittently.
I cannot tie this phenomena with any specific app install, driver update, etc.
When everything is loaded properly (into the system tray) there are nine apps (icons) showing.  Depending on the restart there can be anywhere from 5-9 apps showing in the system tray.
Thank you.
David Winkler
Unlock 1 Answer and 7 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
