troubleshooting Question
Body OnClick problem.
Avatar of Catalin80
Catalin80 asked on
JavaScript
5 Comments1 Solution269 ViewsLast Modified:
Hello.
I have a popup menu that reacts to left-click on different hrefs.
When you click a link, the div of the menu is shown.
In the body.onClick i hide the menu.
The problem is that when i click the link, the body.onClick event is also called
basically hiding the menu instantly.
How do i solve this?
Ty.
Unlock 1 Answer and 5 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
