troubleshooting Question
Imac Power Pc 750 Help Possible Hard drive?
Avatar of paulbarstool
paulbarstool asked on
Apple OSApple Hardware
15 Comments2 Solutions787 ViewsLast Modified:
Since I do some Windows hardware fixes a friend dropped off his IMAc Power PC 750.  320 ram.
I get it to the Apple Hardware Test, I'm able to toggle between the tabs using the Tab key. How can I get to the options on every page.  The mouse I have does not work?  Can I use the Ctrl or Arrow keys like in Windows?
Seems like I have keyboard funtionality but no mouse support.  I just want to run their diagnostics to see if something is wrong.
Why does this Apple hardware test pages appear?
Any place for Apple Imac support?  Knowledgebase?
Any help would be greatly appreciated.
Is this computer worth saving?
Paul
Unlock 2 Answers and 15 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
