troubleshooting Question
Magix Audio Cleaning Lab 10 Problem
Avatar of Ujak
Ujak asked on
Software
7 Comments1 Solution801 ViewsLast Modified:
Whenever I try to use the Cleaning Wizard  I get the following message:
//Failure in module "dscr.dll" at address 0x003f13cf
Exception 0xc0000005 "ACCESS VIOLATION".//
When I Click on "Exit Program" it is fFollowed by:
//Warning!
Internal data structures may have been destroyed. Software may be unstable.//
Magix support took two days to respond and told me to shut down non-essential programs, which I did with no joy.  This .dll file seems to be proprietary to Magix.
Does the failure indicate a bad "dscr.dll" file? If so, do you know how I can fix it other than uninstalling, cleaning registry and reinstalling, which didn't seem to work?
Ujak
Unlock 1 Answer and 7 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
