miketakasaki
Crystal Reports - Problem with Max String Length in formula
I'm using 8.5.
The report is using a formula to format a string that exceeds 254 characters and therefore truncates. How do I get the formula to return more than 254 and get it display on the report?
You're limited in string length by the version of Crystal. What you can do is to have more than one formula - the first returns 254 characters, the next returns 254 more, etc. Position as many as necessary to get the full results.
or you could upgrade. i think from cr 9 on you can use 64,000 chars.
Yes CR9 can handle longer strings. The formula frodoman is using must be either in the database or an external dll. Crystal 8.5 cannot use a string that is longer than 254 in a formula.
mlmcc
mlmcc
