Avatar of spaceplanner
spaceplanner
Using tilde character ~ in data, will it cause problems?
We need to combine 2 pieces of data in one field. The data will not be regular expressions. Subsequently we will need to identify each piece of data within the field. We cannot use space  , comma , ,underscore _ , hyphen - , backslash\ and forwardslash /as separators.
If we were to use the tilde ~ symbol would this have any implications?
We would have data in the table like this:
CW~02
PUNE 01~base
LN\CS~UB2
NY,1525~10
Avatar of Guy Hengel [angelIII / a3]
Flag of Luxembourg image
See answer
no problem at all.
Not probs
But you should not allowed to user to can insert data with tild operator.
