Jerry_Pang
Need help, find BODY tag and values (Pattern matching)
$URL_GRAB = "<body onclick='asdsd asd> ' asd> asd </body>";
<textarea name="result" rows="30" cols="80">
<?php
if (preg_match_all("/^<body.* ?|>.*?<\/b ody>$/i", $URL_GRAB, $matches))
print_r($matches);
else
print_r('none');
</textarea>
closes *result* i could get is
Array
[0] => Array
[0] => <body
[1] => > \' asd> asd </body>
How do i make it
Array
[0] => Array
[0] => <body onclick='asdsd asd> ' asd>
[1] => asd
[2] => </body>
i am having trouble getting my pattern matching right
this pattern "/^<body.*?|>.*?<\/body>$/ i" is lacking..
i want a pattern that
starts with
starts with <body
zero or more
(zero or more [a-zA-Z]characters
(' and matching ending tag ' | " and matching ending tag " )
ends with >
followed by any characters
ends with </body>
help.. going nuts with pattern matching. i tried different pattern matching but it doesnt work, this is the closiest i could get.
<?php
print_r($matches);
else
print_r('none');
</textarea>
Array
[0] => Array
[0] => <body
How do i make it
Array
[0] => Array
[1] => asd
[2] => </body>
starts with
starts with <body
zero or more
ends with >
ends with </body>
"/^(<body[^<]*>)(.*)(<\/bo dy>)$/ims"
/m
/s
the most important element that i need is only the [1] => asd
only what is inside the <body> tag.
i just realize its kinda like xml. but i only need whats inside it.
i tried it on real example like the following..
pvginkel, Roonaan the array [1] is correct. i was wondering why there is no <\/body> in any results.
Array
[0] => <body bgcolor=\"#FFFFFF\" leftmargin=\"0\" topmargin=\"0\" marginwidth=\"0\" marginheight=\"0\" vlink=\"#666666\" text=\"#000000\">
<basefont size=\"3\">
<!-- BEGIN NO PRINT -->
</body>
[1] =>
thyminfo, it does now work on the above example. but i added the Roonaan's #/ims, and it works fine.
