How do I create a mute button for an 'event' sound in Macromedia Flash? Stream sound works easily but compromises the sound quality
I am trying to mute an event sound in Macromedia Flash but have had no success thusfar. I previously learnt how to create a mute button for a 'stream' sync but found the clarity of my sound recording was compromised because of Flash's tendency to override sound settings on publishing.  Converting the sound to an 'event'  maintained the clarity but disabled my use of the mute button. Is there a method for muting an 'event' sound, or is there a formula for improving the output of a stream sync?
mkofahlAsked:
Aneesh ChopraCommented:
simply use following code to stop event sound
stopAllSounds();
Rgds
Aneesh
sam85281Commented:
Quality of event sounds isn't better than streams, you just need to set the quality:
1. In the library right-click the audio file and select Export Settings.
2. Uncheck "Use Imported MP3 Quality" if it's checked
3. Change bitrate to at least 32 for now(you can change it later if it doesn't sound good enough)
4. Change quality to best
5. Uncheck "Convert stereo to mono" if it's checked.
6. Click OK
7. Go to File=>Publish Settings
8. In the Flash tab, at the bottom, make sure override sound settings is not checked
Test it
If you need better quality go back to the Export Settings and set the bitrate higher.
Don't go any higher than neccessary to get decent quality or your file size will be huge.
-Sam
Dushan De SilvaTechnology ArchitectCommented:
stopAllSounds();
Hi mkofahl,
Did you tried with my comment?
BR Dushan
Adobe Flash
