jaycangel
Hashtable problem when working with Threads and Sockets
I'm a newbit at Java, i'm having a problem with creating an employee instance. When the instance is created a hashtable is set up with with some staff information. Problem is that this information seems to be lost somewhere?!
in Client the following line getNoEmployees should write out 2, but instead i get an exception null error. Its like the employeeTable varible has been lost?! Why is this - does it have something to do with threads?
employeeTable = new Employee();
System.out.println(employe eTable);
employeeTable.getNoEmploye es();
I've included all my code bellow. It simply sets up a socket to wait for input from a client, that will return employee information.
Thank you for all you help,
Jason
import java.net.*;
import java.io.*;
import java.util.*;
* Contains employee information
class Employee
public Hashtable employeeTable;
* Construct employee hashtable
public Employee()
Hashtable employeeTable = new Hashtable();
employeeTable.put("a", "10000");
employeeTable.put("b", "20000");
employeeTable.put("c", "30000");
System.out.println("Employ ee Table set up");
System.out.println(employe eTable.get ("a"));
public int getNoEmployees()
return employeeTable.size();
public String getSalaryOf(String i_employeeName)
return (String) employeeTable.get(i_employ eeName);
public int getNoEmployeesWithSalaryGr eaterThan( int i_salary)
return 1;
public class Server extends Thread {
private ServerSocket serverSocket;
public Server serverInstance;
* Constructor to create Server
public Server() {
try { serverSocket = new ServerSocket(2048); }
catch (IOException e) { writeCatch(e, "Error creating server socket"); }
System.out.println("TMA01Q 2 server on port 2048");
this.start(); // run
* Listen and respond to messages
public void run()
System.out.println("Server running");
try
while(true)
System.out.println("Connec tions being accepted");
Socket cSocket = serverSocket.accept (); // accept connection
CSpawn c = new CSpawn(cSocket); // when connection recieved spawn new connection thread
catch (IOException exp)
writeCatch(exp, "Error waiting for connection");
public void isRunning()
System.out.println("is running");
* Start server
public static void main(String[] args)
new Server();
* Write out exception along with message for debugging
public static void writeCatch(Exception iExp, String iMsg)
System.out.println(iMsg + " => " + iExp);
Runtime.getRuntime().exit( 666);
* class handles socket threads made by client
class CSpawn extends Thread
private DataInputStream in;
private PrintStream out;
private Socket client;
private Employee employeeTable;
* Constructor to start connection
public CSpawn(Socket cSocket)
client = cSocket;
try
in = new DataInputStream(client.get InputStrea m());
out = new PrintStream(client.getOutp utStream ());
try
client.close();
catch (IOException exp2)
// do nothing
return;
* Read and Analyse Input
public void run()
String inputLine;
try
while(true)
// read line from steam
inputLine = in.readLine();
out.println("10000");
// ignore
finally
try
client.close();
//ignore
// exceptions ignored because they are most likely caused by client closing
// important exceptions are in server class
Jason
import java.net.*;
import java.io.*;
import java.util.*;
class Employee
public Employee()
return 1;
public Server() {
public void run()
try
while(true)
* Start server
new Server();
client = cSocket;
try
try
client.close();
// do nothing
return;
public void run()
String inputLine;
try
while(true)
// ignore
finally
try
client.close();
//ignore
The local var shadowes the member var
i m late :(
Damn you are good! I've been struggling for ages!!!! And it takes you like 15 second!
Maybe you could help me with this too.
The CSpawn class contains the instance of employee. Which means that everytime someone connects to the server an new employee instance is created along with the CSpawn (connection thread). How would I change the code so that there was only one employee instance located in the server class. I just don't know how the CSpawn class would refer back to the Server class that created it. Is there something like parent.employee ?!
create one in your Server class and pass it as a parameter to the Cspawn constructor
Thanks, that works perfectly
no worries :)
