We've partnered with Certified Experts, Carl Webster and Richard Faulkner, to bring you two Citrix podcasts. Learn about 2020 trends and get answers to your biggest Citrix questions!Listen Now
Querying Times Using Greater Than/Less Than Criteria
makila
makila asked
on
Last Modified: 2008-01-09
I am trying to build a query that tells me if a user logged into the system late.
Table "Temp_Agent_Login" has their logins and logouts and their logid
Table "Reference_Agents" has their logid and emp_id
Table "Temp_Reference_Segments" that has their scheduled login and logout time and emp_id.
I built it in Access 97. Here is the SQL view:
SELECT Temp_Agent_Log.row_date, Reference_Agents.CMSName, Temp_Agent_Log.logid, Min(Temp_Agent_Log.login) AS MinOflogin, Temp_Reference_Segments.START_MOMENT
FROM Temp_Agent_Log INNER JOIN (Reference_Agents INNER JOIN Temp_Reference_Segments ON Reference_Agents.AWID = Temp_Reference_Segments.EMP_ID) ON Temp_Agent_Log.logid = Reference_Agents.CMS_ID
GROUP BY Temp_Agent_Log.row_date, Reference_Agents.CMSName, Temp_Agent_Log.logid, Temp_Reference_Segments.START_MOMENT, Temp_Reference_Segments.SEG_CODE
HAVING (((Temp_Reference_Segments.SEG_CODE)="shift"))
ORDER BY Reference_Agents.CMSName;
I want the query only to output the records where Min(Temp_Agent_Log.login) is greater than Temp_Reference_Segments.START_MOMENT by 5 or more minutes.
Min(Temp_Agent_Log.login) and Temp_Reference_Segments.START_MOMENT are both in Long Time format (e.g. 6:00:00 AM).
I tried to put this in the criteria for Min(Temp_Agent_Log.login) but got no results:
> [START_MOMENT]
I also tried this with no results:
> [Temp_Reference_Segments]![START_MOMENT]
I'm stuck. I have no clue how to proceed.
Watch Question
Try this (in design view)
Add another column, using WHERE as the aggregation
Datediff("n", temp_reference_segments.start_moment,min(temp_agent_log.login)) >4
BTW-What results are you getting?
Use the DateDiff function to compare your dates.
  x=DateDiff("n",date1,date2)
This would return the difference in minutes between two dates then you can test like you wanted.
  If x>5 then...
Here's a reference online. Also look in your help file for more on the function.
http://www.techonthenet.com/access/functions/date/datediff.php
jerryb30-
I did what you said in design view and get this error message:
Can't have aggregate function in WHERE clauses
I created a new column and in the Field just let it autopop with Expr1: [Expr1], I left Table blank, selected Where for the Total, unchecked Show and put your formula in the Criteria.
SELECT Temp_Agent_Log.row_date, Reference_Agents.cmsName, Temp_Agent_Log.logID, Min(Temp_Agent_Log.login) AS MinOflogin, Temp_Reference_Segments.start_moment
FROM Temp_Agent_Log INNER JOIN (Reference_Agents INNER JOIN Temp_Reference_Segments ON Reference_Agents.awid = Temp_Reference_Segments.emp_id) ON Temp_Agent_Log.logID = Reference_Agents.cms_ID
GROUP BY Temp_Agent_Log.row_date, Reference_Agents.cmsName, Temp_Agent_Log.logID, Temp_Reference_Segments.start_moment, Temp_Reference_Segments.seg_code
HAVING (((Temp_Reference_Segments.seg_code)="shift") AND ((DateDiff("n",[start_moment],Min([login])))>4))
ORDER BY Reference_Agents.cmsName;
Instead of using WHERE aggregation, I merely used EXPRESSION as aggregation, and unchecked the VISIBLE box.
Ask the Experts
Perfect! That worked. Thanks!
Thanks. Glad to help.
OR
Please enter a first name
Please enter a last name
