Need EXPERT help..i'm stuck. Need to loop through an output query and add quantities until variable.budget is met
Here is my ouput query below.  On this page i'm going to have a budget variable.  let's say the budget is $10,000 for example.  My query is already pulling the correct records.  It is giving me a maximum of 5 records.  What i need to do is add all the costs up, then keep on adding another quantity for each record until the budget is met WITHOUT going over.  it's okay if it falls under budget.
I'm guessing  I take #form.budget# then if  #cost# LT $10,000 (#form.budget#) add 1 to qty, then Budget - cost, then onto next record...if cost LT remaining form.budget, then add 1 to qty of next record and so on.
I'd be VERY greatful if someone can point me in the right direction here...
my current query which need to add the the quantities to up to and until budget is met
<cfquery name="getUnits" datasource="people" maxrows="5">
select DISTINCT network
from dbo.units, dbo.subregions, dbo.networks, dbo.timeslots
where units.subregion_id = subregions.subregion_id
and units.network_id = networks.network_id
and units.timeslot_id = timeslots.timeslot_id
and networks.network IN (#ListQualify(networks, "'")#)
</cfquery>
<cfset networkRow = 1>
<cfoutput query="getUnits">
  <cfset currentNetwork = network>
<cfquery name="getUnits" datasource="people" maxRows="1">
  SELECT *
AND networks.network =  <cfqueryparam cfsqltype="cf_sql_varchar" value="#currentNetwork#">
and units.subregion_id IN (#form.subregion_id#)
order by #priority#
</cfquery>
 <cfif getUnits.recordcount>
    <cfloop query="getUnits">
      #networkRow# - #currentNetwork# - #subregion_name# - #timeslot# - #cost#  <br>
    </cfloop>
    <cfset networkRow = networkRow + 1>
  </cfif>
</cfoutput>
tags266Asked:
incapitalCommented:
You could use a conditional loop, where the condition is that your running total is less than form.budget. It would look something like this:
<cfset variables.runningTotal = 0>
<cfset variables.counter = 1>
<cfloop condition="variables.runningTotal LTE form.budget" >
    <cfset variables.runningTotal = variables.runningTotal + qryGetUnits.cost[variables.counter]>
    <cfoutput>#getUnits.networkRow[variables.counter]# - #getUnits.currentNetwork[variables.counter]# - #getUnits.subregion_name[variables.counter]# - #getUnits.timeslot[variables.counter]# - #getUnits.cost[variables.counter]#</cfoutput>
    <cfset variables.counter = variables.counter + 1>
</cfloop>
incapitalCommented:
Oh, and you might want to add an additional condition to your loop to include your record count to exit the loop if you've run through all your records...
<cfloop condition="variables.runningTotal LTE form.budget AND variables.counter LTE getUnits.recordCount" >
tags266Author Commented:
looking good incapital...where would i put the second contition in relation to the first condition?  And where would i fit this all within my current query above???
incapitalCommented:
It can all go in the cfloop tag as part of the condition, as below:
</cfloop>
i guess i'm just confused on where to put it within my current query in my first post.
incapitalCommented:
Do you want to break out of your query loop when you max out the budget?
Yes...i want to loop until the budget is met then stop
pcaiooCommented:
try this
<cfparam name="form.budget" default="10000">
<cfset total = 0>
<cfset total = total + cost>
<cfif total gt form.budget>
<cfbreak>
</cfif>
</cfloop>
</cfif>
this mean if budget after the current row is over it will quit the loop and not add the current row
Web Servers
