Wanting to connect a USB device to my laptop using a wireless connection
I have a USB device(controls stage lighting) that connects to my laptop thru USB.....so since I have a "hard connection" to this device, it limits where I can be.  I would like to be able to use the internal wireless card on my laptop to send and receive information to this USB device....sooooo......is there something I can plug my USB device into that will communicate with my laptop thru wireless....or am I dreaming?
Todd
ohmetwAsked:
David523Commented:
I'm not sure any of the items at the below links will work but suspect they would be good choices for interest.
Wireless-G Presentation Player
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1115416829670&pagename=Linksys%2FCommon%2FVisitorWrapper
Print Server
http://www.linksys.com/servlet/Satellite?c=L_Product_C1&childpagename=US%2FLayout&cid=1115416939789&pagename=Linksys%2FCommon%2FVisitorWrapper
I know the above are wireless and do have a USB plug.  I don't know if they are setup in a way that they may or may not be compatible with your system.
Hope this Helps!!!
thoffmanCommented:
I think you want "Cable-Free USB," which is new.
http://www.engadget.com/2006/01/03/belkin-introduces-cablefree-usb-hub/
http://www.belkin.com/pressroom/releases/uploads/01_03_06CableFreeUSB.html
Unfortunately, it doesn't appear that Belkin is going to release this until July, though that's only a couple of months away.
Troy
Printers and Scanners
