Difference between document.write and document.body.innerHTML
Could somebody help me understand why I'm getting different results when using
<body>
  <script>
    document.write(fnMyFunction());
  </script>
</body>
versus
<body>
</body>
<script>
  document.body.innerHTML=fnMyFunction();
</script>
Even a link to an explanation would help a lot.
LVL 2
etd_onlineguysAsked:
Ian GoughCommented:
Hi!
This should claify things,
Ian
Ian GoughCommented:
http://www.wait-till-i.com/index.php?p=104
Sorry with the link it's better!
Ian
etd_onlineguysAuthor Commented:
The problem I'm having is that a function running subsequent to the results of fnMyFunction() is erroring when it tries to find HTML objects or properties created with the innerHTML assignment.  It works fine with the document.write(fnMyFunction()).  Since document.write(fnMyFunction()) is the bigger no-no of the two, I'd like to understand why these two don't behave identically.
Ian GoughCommented:
I'm guessing it's as it's more vague as the link suggests.
"document.write What this does is write out content to the HTML document, inside the body of the document and merrily mixed with the markup" (http://www.wait-till-i.com/index.php?p=104)
Where as innerHTML is maybe more precise as you can have innerHTML, innerTEXT and more more things making it better practice then document.write.
Hope this makes things clearer,
Ian
VIkasumitCommented:
Document.write Simple write the line on the page where it is called, where as body.innerHTML use the DOM object to determine the exact location of the Body Tag within HTML Document
Can you please let me know what is the subsequent function. and what is the error you are getting
VIkasumit
Vikasumit,
I'm receiving an "object expected" error.  It's happening as the script tries to do some window size calculations in JS for a DHTML dropdown menu.  I didn't create the site; I'm making a simulation of it for training.  What I'm doing is putting the HTML to JS strings so that I can create specific pages with a few function calls.  I don't receive an error with the document.write(fnMyFunction()) method, but I do with the document.body.innerHTML = fnMyFunction().  I can get around the problem with document.write, so I'm not overly concerned with the error  My concern is that my understanding of these two methods is obviously flawed, since I believe they should behave identically.
David
I realize what was happening.  Part of the HTML I was trying to write using these methods were <script> includes.  These were not being included when I wrote them to the innerHTML of the body object, so I was getting errors when the script couldn't find the functions.
Thanks for your help, guys.
Ian GoughCommented:
Hey n/p glad you got it sorted.
Ian
HTML
