TheMeeser
Problem with building Bluetooth project
I get this error when I try and build my project.
C:\School\Year4\Tech Project\Programs\Bluetooth \FuelFinde rBT.java:9 1: constant expression required
case SERVER_PORT: {
1 error
Error!: Error: java compiler failed: javac -source 1.3 -target 1.1 -g -O -d C:\DOCUME~1\Chris\LOCALS~1 \Temp\rapc _53dd4af3. dir -bootclass ...
I can't figure out what it means. I even re wrote it to match a smaple from that comes with JDE 4.1
This is the code that has the error:
switch(id)
case SERVER_PORT: {
//Push a new SPPScreen onto the display stack and pop the existing menu
pushScreen( new SPPScreen(null) );
popScreen(myScreen);
return;
default:
if( cookie instanceof Runnable ) {
((Runnable)cookie).run();
break;
How can I fix this problem?
case SERVER_PORT: {
1 error
switch(id)
case SERVER_PORT: {
return;
default:
break;
