Problem Pringing Reports in C#
I have developed an app in c#, in visual studio.net that prints out word documents from a folder on a network. This works fine.
I have now added a crystal report to it, developed in CR10.
I have added it using Project > Add Existing Item.
I then used the toolbox to add the component ReportDocument to the form.
I want to print the report out after the word documents without previewing the report in a viewer.
The code below has been generated for the report, I have used the line application_Form___Overnight_Print1.PrintToPrinter(1,true,1,1); to try and print it
                       Form.Application_Form_Print();
                       this.Application_Form_Print1.FileName = "";
                      this.Application_Form_Print1.InitReport += new (System.EventHandlerthis.Application_Form_Print1_InitReport);
                  // Form1
                 this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
                 this.ClientSize = new System.Drawing.Size(600, 470);
                 this.Name = "Form1";
private void application_Form___Overnight_Print1_InitReport(object sender, System.EventArgs e)
            {            application_Form___Overnight_Print1.PrintToPrinter(1,true,1,1);
I run the report, the word documents print as normal, but no reports are printed to the printer, and I do not receive any error messages.
I have developed the report off a SQL database in CR10 using an odbc connection. The database has a userid and password.
Am I getting nothing because I have not connected to the database and how would I do this or is it something else?
I would also like to specify the printer name to print the reports from and wandered how to do this, the printers are networked and are in the format WSI-01/prn001
Can anybody help with this?
polynominalAsked:
topdog770Commented:
Here's some code snippets that may help.
It's also listed in the order you have to initialize things for crystal reports.
This code is for a report that directly connects to a database, and takes a parameter
ReportDocument crReport;
ReportDocument _crReport;
private Database crDatabase;
private Tables crTables;
private Table crTable;
private TableLogOnInfo crTableLogOnInfo = null ; //new TableLogOnInfo();
private ConnectionInfo crConnectionInfo = null; //new ConnectionInfo ();
this._crReport= new ReportDocument();
crTableLogOnInfo = new TableLogOnInfo();
crConnectionInfo = new ConnectionInfo ();
// for oracle, database name not needed
crConnectionInfo.ServerName = AppConstants.crServerName;
crConnectionInfo.DatabaseName = "";
crConnectionInfo.UserID = AppConstants.crUserName;
crConnectionInfo.Password = AppConstants.crUserPassword;
this.__crReport.Load( AppConstants.crReportPath );
SetReportLogon( ref ReportDocument rpt )
_crReport.SetParameterValue(name, value);
_crReport.PrintOptions.PrinterName = UserSettings.GetInstance().LocalReportPrinterName;
_crReport.PrintToPrinter(Copies, false, 1, 1);
private bool SetReportLogon( ref ReportDocument rpt )
                  if( !rpt.IsLoaded )
                        // error handling should be triggered here
                        System.Windows.Forms.MessageBox.Show("Unable to load report");
                        return false;
                  try
                        // This code works for both user tables and stored procedures
                        //Get the table information from the report
                        crDatabase = rpt.Database;
                        crTables = crDatabase.Tables;
                        //Loop through all tables in the report and apply the
                        //connection information for each table.
                        for (int i = 0; i < crTables.Count; i++)
                              crTable = crTables [i];
                              crTableLogOnInfo = crTable.LogOnInfo;
                              crTableLogOnInfo.ConnectionInfo = crConnectionInfo;
                              crTable.ApplyLogOnInfo(crTableLogOnInfo);
                              //If your DatabaseName is changing at runtime, specify
                              //the table location. For example, when you are reporting
                              //off of a Northwind database on SQL server
                              //you should have the following line of code:
                              //crTable.Location = AppConstants.crServerName  + "."  + crTable.Location.Substring(crTable.Location.LastIndexOf(".") + 1)  ;
                        rpt.Refresh();
                  catch( Exception e )
                        // TODO: wire this into an application error handler
                        System.Windows.Forms.MessageBox.Show( e.Message );
                        return false;
                  return true;
C#
