Solved
Help Help Help Redirecting Virus
Posted on 2006-04-29
5
Last Modified: 2012-06-27
Hi Just trying to fix a machine,
Have run adaware and avast, removed the issues from there,
problem lies when i search in the address bar ie type anything in the address bar, where you epect it to seach
i n the status bar it starts by showing google.com then goes to top-10-stores.com keeps redirecting between the 2, not actually displaying anyhing all the movement is in the status bar.
it then halts in firefox it says this
"Problem loading page
Firefox has detected that the server is redirecting the request for this address in a way that will never complete."
help help help
what should i do net.
Shane
Question by:ShaneJones
  • 3
5 Comments
LVL 65
Assisted Solution
by:SheharyaarSaahil
SheharyaarSaahil earned 800 total points
Check your Hosts file as described here
http://accs-net.com/hosts/how_to_use_hosts.html
Or use Hijackthis, and post here the link to its analysed+saved log file
http://www.alaynah.net/shehar/hijackthis.htm
LVL 12
Author Comment
by:ShaneJones
the hosts files were all ammended before i made this post,
hijack this can you post me the url for the download as i cannot get to any of the pages that the file is located on, it goes straight to the redirect
been looking at the http headers on firefox here is some info for me trying to load google
15:20:08.875[281ms][total 281ms] Status: 302[Found]
GET http://www.google.co.uk/ Load Flags[LOAD_DOCUMENT_URI  LOAD_INITIAL_DOCUMENT_URI  ] Content Size[-1] Mime Type[text/html]
   Request Headers:
      Host[www.google.co.uk]
      User-Agent[Mozilla/5.0 (Windows; U; Windows NT 5.1; en-GB; rv:1.8.0.2) Gecko/20060308 Firefox/1.5.0.2]
      Accept[text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5]
      Accept-Language[en-gb,en;q=0.5]
      Accept-Encoding[gzip,deflate]
      Accept-Charset[ISO-8859-1,utf-8;q=0.7,*;q=0.7]
      Keep-Alive[300]
      Connection[keep-alive]
   Response Headers:
      Date[Sat, 29 Apr 2006 14:20:05 GMT]
      Server[Apache/1.3.34 (Unix) mod_auth_passthrough/1.8 mod_log_bytes/1.2 mod_bwlimited/1.4 PHP/4.3.11 FrontPage/5.0.2.2635 mod_ssl/2.8.25 OpenSSL/0.9.7a]
      Location[http://top-10-shop.com/c.php]
      Connection[close]
      Transfer-Encoding[chunked]
      Content-Type[text/html; charset=iso-8859-1]
15:20:09.156[260ms][total 260ms] Status: 302[Found]
GET http://top-10-shop.com/c.php Load Flags[LOAD_DOCUMENT_URI  LOAD_REPLACE  LOAD_INITIAL_DOCUMENT_URI  ] Content Size[-1] Mime Type[text/html]
   Request Headers:
      Host[top-10-shop.com]
      Keep-Alive[300]
   Response Headers:
      Location[http://www.google.com/spam]
      Connection[close]
15:20:09.416[260ms][total 260ms] Status: 302[Found]
GET http://www.google.com/spam Load Flags[LOAD_DOCUMENT_URI  LOAD_REPLACE  LOAD_INITIAL_DOCUMENT_URI  ] Content Size[-1] Mime Type[text/html]
   Request Headers:
      Host[www.google.com]
      Keep-Alive[300]
   Response Headers:
      Connection[close]
15:20:09.676[11217ms][total 11217ms] Status: 302[Found]
   Request Headers:
      Keep-Alive[300]
   Response Headers:
      Date[Sat, 29 Apr 2006 14:20:17 GMT]
      Connection[close]
15:20:20.903[260ms][total 260ms] Status: 302[Found]
   Request Headers:
      Keep-Alive[300]
   Response Headers:
      Connection[close]
15:20:21.163[1051ms][total 1051ms] Status: 302[Found]
   Request Headers:
      Keep-Alive[300]
   Response Headers:
      Date[Sat, 29 Apr 2006 14:20:18 GMT]
      Connection[close]
15:20:22.224[261ms][total 261ms] Status: 302[Found]
   Request Headers:
      Keep-Alive[300]
   Response Headers:
      Connection[close]
15:20:22.485[2544ms][total 2544ms] Status: 302[Found]
   Request Headers:
      Keep-Alive[300]
   Response Headers:
      Date[Sat, 29 Apr 2006 14:20:21 GMT]
      Connection[close]
15:20:25.029[270ms][total 270ms] Status: 302[Found]
   Request Headers:
      Keep-Alive[300]
   Response Headers:
      Connection[close]
15:20:25.299[0ms][total 0ms] Status: pending[]
GET http://top-10-shop.com/c.php Load Flags[LOAD_DOCUMENT_URI  LOAD_REPLACE  LOAD_INITIAL_DOCUMENT_URI  ] Content Size[unknown] Mime Type[unknown]
   Request Headers:
      Keep-Alive[300]
LVL 47
Accepted Solution
by:
rpggamergirl earned 1200 total points
Here.
Please download HijackThis 1.99.1
http://www.cyberanswers.org/forum/uploads/HijackThis1991.exe
Open Hijackthis, click "Do a system scan and save a logfile" don't fix anything yet, just upload the logfile created, go here and paste your Hijackthis log, http://www.rafb.net/paste/
then at the bottom left corner click "paste"
Copy the address/url and post it here:
Or copy and paste the log at;
http://www.hijackthis.de/
and click "Analyse", click "Save".  Post the link to the saved list here.
LVL 47
Expert Comment
by:rpggamergirl
The link I posted above is a direct download so you shouldn't get redirected.
Your problem could be wareout, but until we see the Hijackthis log we won't know for sure.
You must have an active Internet connection when running this fix, in order to download the Brute Force Uninstaller (BFU) from Merijn's page.
Please download FixWareout from one of these sites:
http://downloads.subratam.org/Fixwareout.exe
http://www.bleepingcomputer.com/files/lonny/Fixwareout.exe
Save it to your desktop and run it. Click Next, then Install, make sure "Run fixit" is checked and click Finish.
The fix will begin; follow the prompts. You will be asked to reboot your computer; please do so. Your system may take longer than usual to load; this is normal.
If you have problems with your connection:
Please go to Start -> Control Panel, and choose Network Connections.  Then right click on your default connection, usually Local Area Connection or Dial-up Connection if you are using Dial-up, and left click on properties.  Double-click on the Internet Protocol (TCP/IP) item and select the radio button that says Obtain DNS servers automatically.  Click OK twice, and restart your computer.
LVL 47
Expert Comment
by:rpggamergirl
Wow! that was so quick!
Is the redirection gone? it was a wareout then?
You didn't have to award points straightaway, some Askers wait for days, :)
Thanks for the points with an "A" grade!
Free Tool: Path Explorer
PREFACE The purpose of this guide is to explain what the SEPC Status Utility is and how it works. I have written the utility using AutoIt and have included the source code for your review. You are welcome to modify the code to your liking, but I wi…
Have you ever tried to find someone you know on Facebook and searched to find more than one result with the same picture? Perhaps someone you know has told you that they have a 'facebook stalker' or someone who is 'posing as them' online and ta…
Established in 1997, Technology Architects has become one of the most reputable technology solutions companies in the country. TA have been providing businesses with cost effective state-of-the-art solutions and unparalleled service that is designed…
Email security requires an ever evolving service that stays up to date with counter-evolving threats. The Email Laundry perform Research and Development to ensure their email security service evolves faster than cyber criminals. We apply our Threat…
Suggested Courses
572 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
