copying database from sql2005 to sql2000 using SSIS and preserving identity
GREAT PROBLEMS! How to copy a database from MS SQL2005 to MS SQL2000 using SSIS AND (!!) keeping the Identitys and default values ?
Wassmann-DK
Wassmann-DK
ptjcbCommented:
If you want to use the Identity values then SSIS is not the choice - unless you want to do a lot of typing. I dropped using SSIS and went to BULK INSERT with the KEEPIDENTITY option.
Join & Write a Comment
Cloud Class® Course: Amazon Web Services - Basic
Are you thinking about creating an Amazon Web Services account for your business? Not sure where to start? In this course you’ll get an overview of the history of AWS and take a tour of their user interface.
