mount problems 500 points help pleaseeeeeee
hello everyone
  I am trying to help a customer do a remote mounting of a partition
   The partition I am trying to mount is labeled /calls. The partition that's on there is cciss-code p1 p2 p3. My not familiar with anything other than sda0, sda1, etc etc. What is cciss-codo. Is the p1, p2 and p3 the way the drive is broken up?
How do I mount the drive I am trying to mount. I told the customer to try mount /dev/sda1, mount /dev/sda2 and mount /dev/sda0. None of which seemed to work. The results were printed out from the df command which on my box show sda1. I can't see the customers noox I am working with him over the phone.
Any Ideas on how to mount that /calls partition?
Thanks in advance
conflikq
conflikq
  • 3
2 Solutions
DonConsolioCommented:
Your customer is probably using a RAID controller with this naming scheme:
/dev/cciss/cXdYpZ
X = controller number (starting at 0) - c0 = 1st RAID controller, c1 = 2nd, ...
Y = disk number per controller (starting at 0) - d0 = 1st disk per controller, d1 = 2nd disk, ...
Z = partition number on disk (starting at 1) - p1 = 1st partition, p2 = 2nd, ...
i.e.:
/dev/cciss/c0d0p1 - partition 1 on first disk attached to first controller
/dev/cciss/c0d3p2 - partition 2 on foutrh disk attached to first controller
for more infos try:
# cat /proc/driver/cciss/cciss0
cciss0: HP Smart Array 5i Controller
Board ID: 0x40100a17
Firmware Version: 2.16
IRQ: 185
Logical drives: 1
Current Q depth: 0
Current # commands on controller: 0
Max Q depth since init: 160
Max # commands on controller since init: 182
Max SG entries since init: 31
       Sequential access devices: 0
cciss/c0d0:       36.41GB       RAID 1(1+0)
# fdisk -l /dev/cciss/c0d0
Disk /dev/cciss/c0d0: 36.4 GB, 36414750720 bytes
255 heads, 32 sectors/track, 8716 cylinders
Units = cylinders of 8160 * 512 = 4177920 bytes
           Device Boot      Start         End      Blocks   Id  System
/dev/cciss/c0d0p1               1        2571    10489664   83  Linux
/dev/cciss/c0d0p2            2572        3857     5246880   83  Linux
/dev/cciss/c0d0p3            3858        5143     5246880   83  Linux
conflikqAuthor Commented:
so is it okay to use something like this as an install guide
fdisk /dev/cciss
n
p
w
mke2fs-J /dev/cciss/c0d1:  disk 1 2nd raid controller
mount -t ext3 /dev/ciss/calls
cat /etc/fstab
use emacs and add line below to /etce
to mount it at bootup edit the fstab
/dev/ciss/calls ext3 default 0 0
cjl7freelance for hireCommented:
Let me clarify this for you!
sda = /dev/sda = the whole drive
c0d0 = /dev/cciss/c0d0 = the whole drive
sda1 = 1'st partition on sda
c0d0p1 = 1'st partition on c0d0
sda2 = 2'nd partition on  sda
c0d0p2 = 2'nd partition on c0d0
So to create this:
/boot = 200 MB
/         = 6 GB
swap = 1 GB
fdisk /dev/cciss/c0d0
n
p
starting bock: <ENTER>
end block: +200m <ENTER>
(1'st partition done, repete for the other two"
Make filesystems
mke2fs -j /dev/cciss/c0d0p2 (have to create on a partition, otherwise the whole disk will be used...)
Edit the fstab
Good luck
Jonas
>fdisk /dev/cciss
not ok - /dev/cciss is a directory where the device files live.
(you can only partition a disk  like /dev/cciss/c0d0)
let's assume you have 1 controller and 1 RAID disk:
# fdisk /dev/cciss/c0d0
and create /dev/cciss/c0d0p1, /dev/cciss/c0d0p2 ...
really c0 (controller 0) d1 (disk1) --> 2nd disk on 1st controller
this would create a filesystem on the entire disk - which is possible
but probably not what you want (it's like "mkfs /dev/sdb" or "mkfs /dev/hdb")
using ALL the disk withour partitioning (only 1 filesystem all over the disk)
you probably want "mke2fs-J /dev/cciss/c0d0p1"
mount -t ext2 /dev/cciss/c0d0p1 /data1
oops - ext2 ==> ext2
Join & Write a Comment
Get expert help—faster!
  • 3
