kepro
Power supplies keep dieing in same PC
I have a Athlon 1700 PC. I leave it on 24/7. A few weeks ago it died when I was AFK for a few hours. I replaced it, and same result a week later. I replaced it again, and also the power strip. Died again today. The house I live in is very old, but the power strip "Replace when not lit" lights are on.
I've tried different Wattages from 400-550 in my replacement power supplies. Any ideas? Thanks in advance.
it could also be that your mobo has the issue in that it may be shorting out the psu, so try replacing that, or try moving all devices to another box to see if they run fine attached to another pc without the old mobo
If you have a digital multimeter with Min/Max you can monitor your outlets for fluctuations. If you're dipping down to 114VAC and up to 124VAC or higher and spikes either way you will experience this.
Go with the BackUPS. :)
Joe Jenkins
