Learn how to a build a cloud-first strategyRegister Now
Solved
Wireless Networking, Can a laptop have a LAN connection and a Wireless connection on the same Network
Posted on 2006-05-10
14
Last Modified: 2013-12-07
I have a LAN with around 30 Desktops on and 10 laptops. The laptops all have wireless cards in and i was wondering if it was possible to buy a Wireless Access Point and have it so when the laptops are moved into a meeting room (where there is no lan connection) it can pick up the Wireless connection, but when they're back at the desk it then uses the faster LAN connection.
So i'd like to have it:
When the laptop is connected to LAN - All files are served through the lan
When the laptop is disconnected from the LAN - Laptop uses Wireless to access files
When the laptop is reconnected to the LAN - All files go through the quicker LAN connection
If i can also do this without having 2 IP addresses as well, that'd be brilliant, although i am aware it might not be possible to do any of this!
Question by:Encams
  • 4
  • 3
  • 2
  • +3
12 Comments
LVL 27
Accepted Solution
by:
pseudocyber earned 500 total points
You might be able to do this with specialized wireless software - which comes with the NIC or the manufacturer of the laptops.
Natively, Windows can use metrics and then make a decision on which connection to use based on the least cost metric.  These are visible in the "route print" screen from the command line.
In my experience, the metrics are unreliable and traffic doesn't always follow them.
LVL 2
Assisted Solution
by:mikefalcone
mikefalcone earned 500 total points
I find it works best if you manually select which connection you wish to use
LVL 27
Expert Comment
by:pseudocyber
I agree with Mike.  I have it set up on my laptop - but they're not both the same IP net.  I run a batch file to manipulate the route table when I want to re-route traffic.
Microsoft Certification Exam 74-409
Veeam® is happy to provide the Microsoft community with a study guide prepared by MVP and MCT, Orin Thomas. This guide will take you through each of the exam objectives, helping you to prepare for and pass the examination.
LVL 3
Assisted Solution
by:Newsboy
Newsboy earned 500 total points
Most laptops anymore come with a button to enable/disable wireless, have you checked to see if this is an option on your laptops. If so all they have to do is hit that button.
LVL 1
Assisted Solution
by:redgun
redgun earned 500 total points
In order to automatically switch between your wired lan port and your wireless card and keep your same ip address you will have to create a bridge. (I am assuming you have windows XP)
here is a extract from windows help
To bridge connections
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure.
Open Network Connections.
Under LAN or High-Speed Internet, hold down the CTRL key and select each of the private network connections that you want to be part of the bridge.
Right-click one of the highlighted private network connections, and then click Bridge Connections.
 Notes
To open Network Connections, click Start, click Control Panel, and then double-click Network Connections.
You must select at least two eligible network connections to create a bridge.
Only Ethernet, IEEE-1394 adapters, or Ethernet compatible adapters such as Wireless and home phoneline adapters (HPNA), can be part of the network bridge.
Adapters that have Internet Connection Sharing (ICS) enabled cannot be part of the network bridge and will not appear on the Network Bridge checklist. Similarly, the Add to Bridge option is available only for adapters that you can add as connections to Network Bridge.
Do not create a bridge between a public Internet connection and a private network connection, or add the public Internet connection to an existing network bridge. To do so will create an unprotected link between your network and the Internet, and your network could be vulnerable to intrusions.
You can create only one network bridge on a computer, but the bridge can accommodate any number of network connections.
You cannot create a bridge connection on a computer running Windows 2000 or earlier versions of Windows.
Network adapters that previously appeared under LAN or High-Speed Internet, appear under Network Bridge when they are added as connections. Network adapters that provide Internet connectivity, such as DSL and cable modems, cannot be bridged and will always appear under LAN or High-Speed Internet.
LVL 7
Expert Comment
by:knightrider2k2
I haven't tried this but may be it works
On windows xp computer go to "Network connections". Click "Advanced settings" from "Advanced" menu. Bring the local area connection on the top.
LVL 2
Expert Comment
by:mikefalcone
in response to redgun's post. If you do this make sure you have spanning tree turned on on your switches, otherwise you will bring down your network.
Author Comment
by:Encams
Spanning tree? I've never heard of that? We're just using normal gigabit Netgear switches.
LVL 27
Expert Comment
by:pseudocyber
Spanning Tree Protocol was designed to prevent layer 2 switching/bridging loops.  If you introduce a loop into a switched lan, without spanning tree - the nature of switching and broadcasts will quickly crash your network or portions of it.
Quote, "Where two bridges are used to interconnect the same two computer network segments, spanning tree is a protocol that allows the bridges to exchange information so that only one of them will handle a given message that is being sent between two computers within the network. The spanning tree protocol prevents the condition known as a bridge loop."
http://searchnetworking.techtarget.com/sDefinition/0,290660,sid7_gci214602,00.html
Author Comment
by:Encams
Bridging connections sounds like it'll kill my network, so can anyone recommend a program that would be able to detect if it's connected to a LAN or Wireless and pick the best. Preferebly free too :)
LVL 27
Expert Comment
by:pseudocyber
>>pick the best
What's the criteria for "best"?  Wired is ALWAYS better than wirelesss - except for mobility.
The best, free utility for picking the connection is the user.
Author Comment
by:Encams
I'm looking for the fastest connection speed, sorry for not being cleared.
The idea is people in the office would be able to unplug laptops and carry them into meetings without having to select a different connection. I was hoping to get something to do this automatically as the technical user base here isn't the greatest.
Vote for the Most Valuable Expert
It’s time to recognize experts that go above and beyond with helpful solutions and engagement on site. Choose from the top experts in the Hall of Fame or on the right rail of your favorite topic page. Look for the blue “Nominate” button on their profile to vote.
This article explains the fundamentals of industrial networking which ultimately is the backbone network which is providing communications for process devices like robots and other not so interesting stuff.
In this article I will be showing you how to subnet the easiest way possible for IPv4 (Internet Protocol version 4). This article does not cover IPv6. Keep in mind that subnetting requires lots of practice and time.
Viewers will learn how to connect to a wireless network using the network security key. They will also learn how to access the IP address and DNS server for connections that must be done manually. After setting up a router, find the network security…
In this brief tutorial Pawel from AdRem Software explains how you can quickly find out which services are running on your network, or what are the IP addresses of servers responsible for each service. Software used is freeware NetCrunch Tools (https…
810 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
