[Okta Webinar] Learn how to a build a cloud-first strategyRegister Now
Tiny laptop recovery process running into errors, ( Tclone Oem harddrive recovery system) Not compatible with reload process.
I have a Tiny Mediabook M2600 Laptop with a dying Harddrive.
I went to replace the harddrive "Toshiba Mk4025GAS" with a Hitachi drive but when i go to use the Tiny recovery cd's i get the error
"This system is not compatible with this reload process
requested Reload Version -3.50"
I thought this may be down to it being locked to the paticular make & model of hard drive, so i've purchased a "Toshiba Mk4025GAS" the exact same size as the one i'm replacing but still i get the same error??
can anyone help?
mendmycomputer
mendmycomputer
2 Solutions
kkattfishCommented:
check out this thread, looks like it is a similar problem and could help you out.  http://www.experts-exchange.com/Hardware/Desktops/Q_21824167.html
and235100Commented:
It may be that the recovery cd is hardcoded with the serial of the old hdd.
You are going to need a standard win xp cd, I think.
mendmycomputerAuthor Commented:
Yes after much deliberation i've come to the conclusion that the ****s at tiny lock it to your HDD serial, which is just great so long as it's not the HDD that fails. thanks a bunch TINY!
