ajdunne
code to help with maths problem
Hi experts,
I have a tricky problem that I don't know how to attack:
I need a routine that creates all the possible numbers from a set of individual digits.
For example, suppose you have the digits 1, 3 and 5.
Possible numbers are:
135
153
315
351
513
531
You can only use each digit once per number.
I'm not sure how to start - if you can point me in the right direction, I would be grateful.
I am comfortable using VB in MS Access - my preferred environment.
Thanks in advance.
135
153
315
351
513
531
Thanks in advance.
Ideally, I want a solution that I can extend to 3, 4, 5 or 6 digits, but each case is treated seperately, i.e.
case 1 is always 3 digits
case 2 is always 4 digits, etc
In all cases, the digits are unique: Digit1 <> Digit2 <> Digit3 [<> Digit4...]
Option Explicit
Private Sub Form_Load()
'here 4 digits, increase array to how many digits you want
Dim digits(1 To 4) As String
digits(1) = "3"
digits(2) = "1"
digits(3) = "3"
digits(4) = "4"
Dim out() As String
digitizer digits, out
Dim i As Integer
For i = 1 To UBound(out)
Debug.Print i, out(i)
Next
End Sub
Private Sub digitizer(digits() As String, numbers() As String)
Dim digits2() As String
Dim numbers2() As String
Dim numbers3() As String
Dim i As Long
Dim j As Long
Dim k As Long
Dim l As Long
Dim ni As Long
Dim sPivot As String
Dim sNew As String
If UBound(digits) = 1 Then
ReDim numbers(1)
numbers(1) = digits(1)
Else
ReDim digits2(1 To UBound(digits) - 1)
ReDim numbers3(0 To 0)
For i = 1 To UBound(digits)
k = 0
For j = 1 To UBound(digits)
If i <> j Then
k = k + 1
digits2(k) = digits(j)
End If
Next
sPivot = digits(i)
digitizer digits2, numbers2
For l = 1 To UBound(numbers2)
For j = 0 To UBound(digits2)
sNew = Left(numbers2(l), j) + sPivot + Mid(numbers2(l), j + 1)
ni = UBound(numbers3) + 1
ReDim Preserve numbers3(ni)
numbers3(ni) = sNew
Next
Next
Next
Dim bSwap As Boolean
Dim sSwap As String
Do
bSwap = False
For j = 1 To UBound(numbers3) - 1
If numbers3(j) > numbers3(j + 1) Then
sSwap = numbers3(j)
numbers3(j) = numbers3(j + 1)
numbers3(j + 1) = sSwap
bSwap = True
End If
Next
Loop Until Not bSwap
k = 0
If numbers3(j) <> numbers3(j - 1) Then
k = k + 1
ReDim Preserve numbers(k)
numbers(k) = numbers3(j)
End If
Next
End If
End Sub
digits(1) = "3"
digits(2) = "1"
digits(3) = "3"
digits(4) = "4"
Dim out() As String
Dim i As Integer
Next
End Sub
Dim i As Long
Dim j As Long
Dim k As Long
Dim l As Long
Dim ni As Long
Dim sNew As String
ReDim numbers(1)
Else
k = 0
If i <> j Then
k = k + 1
End If
Next
sPivot = digits(i)
numbers3(ni) = sNew
Next
Next
Next
Dim sSwap As String
Do
bSwap = False
sSwap = numbers3(j)
bSwap = True
End If
Next
k = 0
k = k + 1
End If
Next
End If
End Sub
if you run it with the setup below, you should get 120 combinations, which is 6!/3!=720/6=120
Dim digits(1 To 6) As String
digits(1) = "1"
digits(2) = "3"
digits(3) = "5"
digits(4) = "8"
digits(5) = "8"
digits(6) = "8"
Dim out() As String
Dim i As Integer
Next
digits(1) = "1"
digits(2) = "3"
digits(3) = "5"
digits(4) = "8"
digits(5) = "8"
digits(6) = "8"
Dim out() As String
Dim i As Integer
Next
I feel my posting was a correct answer.
Hi deighton,
Thanks for your feedback on this, but I could not make your code work.
Sorry, probably my fault.
I did finally find an excel spreadsheet that contained the vba code I needed.
I found it at
http://www.geocities.com/SiliconValley/7043/ue.html
Experts, may I request a refund of these points.
ajdunne
I found it at
ajdunne
sorry missed the comment about access
AW
